Ana içeriğe geç
Motorola i90c Midframe Replacement
Neye ihtiyacın var
  1. Motorola i90c Midframe Replacement, Battery: adım 1, 3 resimden 1. Motorola i90c Midframe Replacement, Battery: adım 1, 3 resimden 2. Motorola i90c Midframe Replacement, Battery: adım 1, 3 resimden 3.
    • Slide the notch downward while pulling the back cover off to remove it.
    FixBot'a Sor
    Yorum Ekle
  2. Motorola i90c Midframe Replacement: adım 2, 3 resimden 1. Motorola i90c Midframe Replacement: adım 2, 3 resimden 2. Motorola i90c Midframe Replacement: adım 2, 3 resimden 3.
    • Use your fingers to push the battery upward from the bottom.
    • Lift upwards to remove the battery.
    FixBot'a Sor
    Yorum Ekle
  3. Motorola i90c Midframe Replacement, Antenna: adım 3, 2 resimden 1. Motorola i90c Midframe Replacement, Antenna: adım 3, 2 resimden 2.
    • Unscrew the antenna in a counter-clockwise fashion.
    • Remove the aluminum cover.
    FixBot'a Sor
    Yorum Ekle
  4. Motorola i90c Midframe Replacement, Midframe: adım 4, 3 resimden 1. Motorola i90c Midframe Replacement, Midframe: adım 4, 3 resimden 2. Motorola i90c Midframe Replacement, Midframe: adım 4, 3 resimden 3.
    • Unscrew the 3 screws shown.
    • Lift the right part of the Nextel logo
    • Remove the screw underneath.
    FixBot'a Sor
    Yorum Ekle
  5. Motorola i90c Midframe Replacement: adım 5, 2 resimden 1. Motorola i90c Midframe Replacement: adım 5, 2 resimden 2.
    • Forcing the cover off could damage the ribbon cable, so be careful when doing so.
    • Gently lift the back cover off.
    FixBot'a Sor
    Yorum Ekle
  6. Motorola i90c Midframe Replacement: adım 6, 3 resimden 1. Motorola i90c Midframe Replacement: adım 6, 3 resimden 2. Motorola i90c Midframe Replacement: adım 6, 3 resimden 3.
    • Find the connection between the headphone jack and logic board.
    • Begin separating the two pieces, slowly and carefully.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Grant Glazebrook
7 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 29-61, Johann Spring 2010 Cal Poly, Team 29-61, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S29G61
4 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 30
Her zaman: 1,681
