Ana içeriğe geç
Motorola syn1654A Headphone Speaker Replacement
Neye ihtiyacın var
  1. Motorola syn1654A Headphone Speaker Replacement, Headphone Speaker: adım 1, 1 resimden 1.
    • Make sure the headphones are off and unplugged from any devices.
    • Remove leather headphone cushion by pulling edge towards middle of headphone.
    • It should slip off the device.
  2. Motorola syn1654A Headphone Speaker Replacement: adım 2, 1 resimden 1.
    • Carefully peel back foam pad to prevent tearing.
    • It is glued at both the top and bottom.
  3. Motorola syn1654A Headphone Speaker Replacement: adım 3, 1 resimden 1.
    • Use the T6 torx screwdriver to remove the three screws holding the speaker in place.
    • To avoid stripping screws, be sure to use the right screw bit oriented perpendicular to the face of the screw.
  4. Motorola syn1654A Headphone Speaker Replacement: adım 4, 1 resimden 1.
    • With the speaker removed from the speaker module, clip the black and white wires on the back of the speaker, as shown.
    • Solder wires onto corresponding pads of replacement speaker.
    • For soldering see the ifixit soldering guide: How To Solder and Desolder Connections
Sonuç
John Ware
325 İtibar
2 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 5-1, Lauer Spring 2014 Michigan Tech, Team 5-1, Lauer Spring 2014 üyesi
MTU-LAUER-S14S5G1
2 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 414
