Ana içeriğe geç
Motorola syn1654A Speaker Module Replacement
Neye ihtiyacın var
  1. Motorola syn1654A Speaker Module Replacement, Speaker Module: adım 1, 2 resimden 1. Motorola syn1654A Speaker Module Replacement, Speaker Module: adım 1, 2 resimden 2.
    • See the speaker replacement guide and follow steps 1 and 2.
  2. Motorola syn1654A Speaker Module Replacement: adım 2, 1 resimden 1.
    • Use the T6 torx screwdriver to remove the seven screws located around the headphone cover and place the screws in a safe place.
    • To avoid stripping screws, be sure to use the right drill bit oriented perpendicular to the face of the screw.
  3. Motorola syn1654A Speaker Module Replacement: adım 3, 1 resimden 1.
    • Carefully lift the speaker out of its housing while leaving all wires connected.
  4. Motorola syn1654A Speaker Module Replacement: adım 4, 1 resimden 1.
    • Lift the module out of the headphone cup, leaving all wires attached.
    • Clip the two wires circled in orange.
    • Now that the speaker is free set it aside.
    • Clip the two wires circled in yellow.
    • Replace speaker module and solder it to the two wires circled in orange.
    • Now solder the speaker wires (circled in yellow) back to the module.
    • For soldering see the ifixit soldering guide: How To Solder and Desolder Connections
Sonuç
Ben
104 İtibar
1 Kılavuz yazıldı
Ekip
Michigan Tech, Team 5-1, Lauer Spring 2014 Michigan Tech, Team 5-1, Lauer Spring 2014 üyesi
MTU-LAUER-S14S5G1
2 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 12
Her zaman: 252
