Ana içeriğe geç
Mounting Plate  Replacement
Damaris Aguirre
Damaris Aguirre ve 4 diğer katkıda bulunanlar
En son April 2, 2020 tarihinde güncellendi
5 - 10 dakika
Orta
Daha İyi Resimler Gerekli
If you have trouble with your mount plate or want to replace it, this guide will give you detailed steps to follow in order to successfully replace your mounting plate. This replacement should take approximately 5-10 minutes to complete.
Neye ihtiyacın var
Aletler
  1. Mounting Plate  Replacement, Mounting Plate: adım 1, 1 resimden 1.
    • Hold Ring Spotlight Cam and hold it backward to you.
  2. Mounting Plate  Replacement: adım 2, 1 resimden 1.
    • Remove the screw using the screwdriver and head tool PH00.
  3. Mounting Plate  Replacement: adım 3, 1 resimden 1.
    • Open the top lid.
  4. Mounting Plate  Replacement: adım 4, 3 resimden 1. Mounting Plate  Replacement: adım 4, 3 resimden 2. Mounting Plate  Replacement: adım 4, 3 resimden 3.
    • Press the mounting plate button and slide upwards.
    What is replacement part?
    Kristianne Bossie - Yanıt
Sonuç
Bir başkası bu kılavuzu tamamladı.
Damaris Aguirre
31 İtibar
2 adet Kılavuz yazıldı
1Rehber Yorum
Hello, hope you are doing well. Does anyone know if we can buy a replacement mounting plate for the Ring Spotlight Cam Battery? Mine is cracked and Ring doesn’t seem to sell replacements. Thanks!
Suresh Ram - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 21
Her zaman: 1,134
