Ana içeriğe geç
Mpow 059 Ear Cushion Replacement
Neye ihtiyacın var
  1. Mpow 059 Ear Cushion Replacement, Ear Cushion: adım 1, 2 resimden 1. Mpow 059 Ear Cushion Replacement, Ear Cushion: adım 1, 2 resimden 2.
    • Place the iFixit opening tool between the soft ear cushion and the hard plastic of the speaker.
    • Pry the soft ear cushion away from the hard plastic using a moderate amount of pressure.
    • There is adhesive holding the ear cushion to the speaker so it may take a little patience to remove.
    • Applying too much pressure can damage ear cushion.
    You state the battery is behind the right ear cup, it was behind the left cup on mine. The picture shows "L".
    Art Horton - Yanıt
    Hi Art, thank you for pointing this out! We will make that correction. Sorry for any confusion.
    Sarah Westberg -
  2. Mpow 059 Ear Cushion Replacement: adım 2, 1 resimden 1.
    • Remove the ear cushion away from the speaker to completely detach it from the headphones.
    Und was weiter. Wie soll ich die neue Ohrpolster an Die Kopfhörer montieren???
    Markieton - Yanıt
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Danielle Furtado
511 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team E-1, Gurgel Spring 2022 UMass Dartmouth, Team E-1, Gurgel Spring 2022 üyesi
UMASSD-GURGEL-S22SEG1
3 Üyeler
4 adet Kılavuz yazıldı
8Kılavuz Yorumları
Really amazing
hopeful Hr - Yanıt
thank you. very helpfule.
P Gill - Yanıt
These instructions do not mention anything about the fact that you need a new adhesive to make the new earpads stay. Now I won't have headphones until I'm able to purchase an adhesive.
Cody Owens - Yanıt
Is there a recommendation on the replacement ear pads?
Some say glue is needed but does this depend on the replacement pads?
ms13sp - Yanıt
Works great. I have replaced my earpads 3 times with no glue. I use these MOKOS earpads from amazon. Replacement earpads for Mpow 059
Thanks for the step by step guide. I love these Mpow headphones, mostly for the controls on the right ear.
anotherdee - Yanıt
Wie soll ich die neue Ohrpolster montieren. Brauch man ein Kleber da zu und wenn ja, welche??
Markieton - Yanıt
Wie soll ich die neue Ohrpolster auf meine Kopfhörer montieren, brauche ich ein Kleber und wenn ja, welche?
Markieton - Yanıt
Per this Video - https://www.youtube.com/watch?v=ytQSCxTP...
It shows the ear pad ring gets slipped under retainers on the black plastic ring that snaps off with the ear pad during the removal process, then snapped back on. The video shows no adhesive being used. Though you can use some if it makes you feel better. Probably use a rubber glue in case you ever want to remove them again. (FYI - The video shows the removal process as being much easier than it is, She probably removed it prior to filming and put it back to make the video move along more quickly. The guide provided in this page is more accurate as far as the removal taking some time and care) Unless the replacement pads you purchased doesn't have the soft ring at the base to slip around the retainers (not sure it that type exist) It shouldn't require adhesive.
Martin Norvaisa - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 30
Son 30 gün: 87
Her zaman: 7,348
