Ana içeriğe geç
NETGEAR WGT624 v3 Capacitor Replacement
Neye ihtiyacın var
  1. NETGEAR WGT624 v3 Capacitor Replacement, Lower Case: adım 1, 1 resimden 1.
    • Turn the device so that the bottom is facing up.
    FixBot'a Sor
    Yorum Ekle
  2. NETGEAR WGT624 v3 Capacitor Replacement: adım 2, 3 resimden 1. NETGEAR WGT624 v3 Capacitor Replacement: adım 2, 3 resimden 2. NETGEAR WGT624 v3 Capacitor Replacement: adım 2, 3 resimden 3.
    • Use the plastic opening tool to carefully lift the rubber stops in each corner.
    • Do not completely remove the rubber stops, because they are difficult to replace.
    FixBot'a Sor
    Yorum Ekle
  3. NETGEAR WGT624 v3 Capacitor Replacement: adım 3, 2 resimden 1. NETGEAR WGT624 v3 Capacitor Replacement: adım 3, 2 resimden 2.
    • Unscrew the 4 11.8 mm T-8 Torx screws from each corner of the device.
    FixBot'a Sor
    Yorum Ekle
  4. NETGEAR WGT624 v3 Capacitor Replacement: adım 4, 2 resimden 1. NETGEAR WGT624 v3 Capacitor Replacement: adım 4, 2 resimden 2.
    • Lift the lower case straight up from the rest of the router.
    FixBot'a Sor
    Yorum Ekle
  5. NETGEAR WGT624 v3 Capacitor Replacement, Motherboard: adım 5, 2 resimden 1. NETGEAR WGT624 v3 Capacitor Replacement, Motherboard: adım 5, 2 resimden 2.
    • Remove the clear plastic casing by lifting it straight up from the router.
    FixBot'a Sor
    Yorum Ekle
  6. NETGEAR WGT624 v3 Capacitor Replacement: adım 6, 2 resimden 1. NETGEAR WGT624 v3 Capacitor Replacement: adım 6, 2 resimden 2.
    • Separate the motherboard from the top shell by lifting it straight up from the router.
    FixBot'a Sor
    Yorum Ekle
  7. NETGEAR WGT624 v3 Capacitor Replacement, Capacitor: adım 7, 1 resimden 1.
    • Turn the motherboard so that the top is facing upwards.
    • Place the motherboard on a clean flat surface.
    FixBot'a Sor
    Yorum Ekle
  8. NETGEAR WGT624 v3 Capacitor Replacement: adım 8, 1 resimden 1.
    • Locate the four capacitors.
    FixBot'a Sor
    Yorum Ekle
  9. NETGEAR WGT624 v3 Capacitor Replacement: adım 9, 2 resimden 1. NETGEAR WGT624 v3 Capacitor Replacement: adım 9, 2 resimden 2.
    • Turn the motherboard so that the bottom is facing upwards.
    • Locate the two soldered contacts for each capacitor.
    FixBot'a Sor
    Yorum Ekle
  10. NETGEAR WGT624 v3 Capacitor Replacement: adım 10, 2 resimden 1. NETGEAR WGT624 v3 Capacitor Replacement: adım 10, 2 resimden 2.
    • Do not refer to the pictures in this step for correct soldering and de-soldering techniques. They are solely for illustration purposes.
    • Desolder the soldered connections between the capacitors and the motherboard, and pull the capacitor from the motherboard.
    • For proper soldering and de-soldering techniques, refer here.
    • When reinstalling the capacitor, make sure the negative side of the capacitor is aligned with the shaded white region of the circle.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jonathon Sather
45 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-31, Amido Winter 2013 Cal Poly, Team 3-31, Amido Winter 2013 üyesi
CPSU-AMIDO-W13S3G31
3 Üyeler
12 adet Kılavuz yazıldı
1Rehber Yorum
my router NETGEAR WNR 612 WIFI LED NOT GLOWING PLEASE HLP ME IN REPAIRING
Vinod Kumar Polakonda - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 1,827
