Giriş
This guide is going to show you how to take apart the blaster to reach the spring that is located in cocking mechanism of the Nerf.
Neye ihtiyacın var
Once the screws have been removed, lift the top half of the gun off.
Take care and try not to lose any smaller pieces as you open it up.
Locking tab for attachments.
what is a locking tab? and where do i see it? sorry my english is bad
its the front sight post
Remove the screw on the inside of the gun.
Screw specifications: Philips head, Head Diameter= 4.3mm, Thread Pitch= 1mm, Screw Length= 8mm
Locate and remove the indicated screw.
This is the spring controlling the cocking mechanism. If the spring is damaged, replace it.
Where do I buy a new one
hi my spring is broken to and i was wondering where to buy a replacement spring for this nerf blaster
17 farklı kişi bu kılavuzu tamamladı.
21Kılavuz Yorumları
Where does the locking tab in step 5 go
on the top of the gun(Seeing from the position as if you're aiming)
Its only there for accesory so it still works if you don't return it
chanisco -
What type of spring is it and where can I buy it because I stretched it too much and now it won't work
Me too, someone please answer this!
Where did the little, orange rectangle that appears in Step 5 come from and where do I put it back??
Ooops, okay, got it. I just saw the message above on this same topic!
Where could I get a replacement for the spring that pulls the cocking mechanism back?
Please any links or information on the replacement springs? You can’t complete this fix without new springs….
So I had the same problem I fixed the gun without the return spring. It isn’t worth Jack. I found with a side by side comparison of the disruptor and Strongarm that on the catch the disruptor has a better spring which fits on an internal notch. On the Strongarm you have to compress the catch spring a bit to fit it in.
The piece of plastic that hoocks on to the plunger brock off so I cant find a spare part
What should I do?
Where can i buy a replacement spring for the priming handle on a disruptor
mine will slam fire, but not single fire. any tips?
I have cocking holder parts
