Ana içeriğe geç
Nest Cam IQ Mounting Stand Replacement
Jas Ownby
Jas Ownby ve 3 diğer katkıda bulunanlar
En son December 28, 2023 tarihinde güncellendi
30 dakika - 1 saat
Orta
If your Nest Cam IQ mounting stand is broken or can no longer mount to the desired surface, it requires replacement.
A proper mounting stand allows you to set up the Nest Cam IQ at your preferred viewpoint. If you notice your viewpoint has changed and the mounting stand is no longer mounted, consider changing out your mounting stand.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Nest Cam IQ Mounting Stand Replacement, Mounting Stand: adım 1, 1 resimden 1.
    • To soften the adhesive holding the camera together, heat up the edges of the glass lens using a heated iOpener on the device. Alternatively, you can use a heat gun to loosen the adhesive.
    • Leave the Opener on the glass lens for two minutes.
    • Be careful not to burn yourself while handling the hot iOpener. For more information on the Opener, use the iOpener Instructions Guide.
  2. Nest Cam IQ Mounting Stand Replacement: adım 2, 1 resimden 1.
    • Use an opening tool to split apart the glass lens from the body.
    • Be careful to not break the glass when prying from the body.
  3. Nest Cam IQ Mounting Stand Replacement: adım 3, 1 resimden 1.
    • Place a suction cup on the glass lens that you heated up with the iOpener.
    • Press down on the suction cup to create a seal, and pull up with force to create a separation between the glass lens and the body.
    • Pull off the glass lens using the suction cup.
  4. Nest Cam IQ Mounting Stand Replacement: adım 4, 2 resimden 1. Nest Cam IQ Mounting Stand Replacement: adım 4, 2 resimden 2.
    • Carefully disconnect the flat black ribbon cable connecting the metal plate to the LED.
    • Remove the metal plate.
  5. Nest Cam IQ Mounting Stand Replacement: adım 5, 2 resimden 1. Nest Cam IQ Mounting Stand Replacement: adım 5, 2 resimden 2.
    • Remove the five 9mm TR6 Torx screws from the LED cover.
    • Pull off the LED cover.
    • As you remove the LED cover, be careful not to tear the flat black ribbon connecting the LED to the motherboard.
  6. Nest Cam IQ Mounting Stand Replacement: adım 6, 3 resimden 1. Nest Cam IQ Mounting Stand Replacement: adım 6, 3 resimden 2. Nest Cam IQ Mounting Stand Replacement: adım 6, 3 resimden 3.
    • Carefully disconnect the flat black ribbon cable connecting the LED to the motherboard.
    • Remove the LED cover.
  7. Nest Cam IQ Mounting Stand Replacement: adım 7, 1 resimden 1.
    • Remove the two 7mm TR6 Torx screws securing the camera.
    • Carefully pull out the camera.
    • As you remove the camera, be careful not to tear the flat black ribbon connecting the camera to the motherboard.
  8. Nest Cam IQ Mounting Stand Replacement: adım 8, 2 resimden 1. Nest Cam IQ Mounting Stand Replacement: adım 8, 2 resimden 2.
    • Carefully disconnect the flat black ribbon cable connecting the camera to the motherboard.
    • Remove the camera.
  9. Nest Cam IQ Mounting Stand Replacement: adım 9, 3 resimden 1. Nest Cam IQ Mounting Stand Replacement: adım 9, 3 resimden 2. Nest Cam IQ Mounting Stand Replacement: adım 9, 3 resimden 3.
    • Remove the three 19mm TR6 Torx screws from the camera holder.
    • Carefully lift the tab up and away from the camera holder.
    • Remove the camera holder.
  10. Nest Cam IQ Mounting Stand Replacement: adım 10, 2 resimden 1. Nest Cam IQ Mounting Stand Replacement: adım 10, 2 resimden 2.
    • Remove the one 4mm TR6 Torx screw from the clear cover.
    • Remove the clear cover.
  11. Nest Cam IQ Mounting Stand Replacement: adım 11, 3 resimden 1. Nest Cam IQ Mounting Stand Replacement: adım 11, 3 resimden 2. Nest Cam IQ Mounting Stand Replacement: adım 11, 3 resimden 3.
    • Remove the four 11mm TR6 Torx screws from the clamp securing the mounting stand.
    • Remove the clamp.
    • Carefully pull away the cables connecting the mounting stand to the body.
  12. Nest Cam IQ Mounting Stand Replacement: adım 12, 1 resimden 1.
    • Carefully remove the mounting stand.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jas Ownby
806 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 25
Her zaman: 130
