Ana içeriğe geç
Nest Cam Wi-Fi Cable Replacement
Neye ihtiyacın var
  1. Nest Cam Wi-Fi Cable Replacement, Wi-Fi Cable: adım 1, 1 resimden 1.
    • Remove the four 6 mm screws from the back panel with the J000 Phillips head screwdriver.
    • We suggest designated areas to keep track of all screws.
  2. Nest Cam Wi-Fi Cable Replacement: adım 2, 3 resimden 1. Nest Cam Wi-Fi Cable Replacement: adım 2, 3 resimden 2. Nest Cam Wi-Fi Cable Replacement: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Open the back panel completely to expose the inside of the Nest Cam.
    • Using the tweezers, disconnect the red and black mic cable from the motherboard.
  3. Nest Cam Wi-Fi Cable Replacement: adım 3, 3 resimden 1. Nest Cam Wi-Fi Cable Replacement: adım 3, 3 resimden 2. Nest Cam Wi-Fi Cable Replacement: adım 3, 3 resimden 3.
    • Disconnect the black Wi-Fi cable from the top of the motherboard with tweezers.
    • Use a plastic spudger to lift the motherboard and camera up enough to expose and disconnect the white cable with the tweezers.
    • Remove motherboard and camera completely from the housing.
  4. Nest Cam Wi-Fi Cable Replacement: adım 4, 1 resimden 1.
    • Using a soldering iron, melt away the base of the Wi-Fi cable until it can be removed. Use this guild for assistance with soldering.
    • Ensure when you solder the new cable back on that all connector ends are positioned correctly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jade Weiss
662 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Leahy Spring 2016 USF Tampa, Team 1-1, Leahy Spring 2016 üyesi
USFT-LEAHY-S16S1G1
7 Üyeler
10 adet Kılavuz yazıldı
2Kılavuz Yorumları
I have broken the cable attached to Nest camera. Can you get replacement or repair the lead? Hope i haven't got to buy a new camera
Kerrie Davies - Yanıt
I have broken lead attached to Nest camera. Can i get a replacement or repair it? Hope i havent got to buy a new camera.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 30
Her zaman: 4,549
