Ana içeriğe geç
Nest x Yale Lock Keypad Replacement
Neye ihtiyacın var
  1. Nest x Yale Lock Keypad Replacement, Keypad: adım 1, 1 resimden 1.
    • Unscrew all available screws that you can see from the back.
    • The screws are 0.25 inches phillips screws.
    • Make sure to not lose any of the screws, and keep track of them.
    FixBot'a Sor
    Yorum Ekle
  2. Nest x Yale Lock Keypad Replacement: adım 2, 1 resimden 1.
    • Once you have unscrewed all the screws carefully remove the metal covering.
    • Make sure that the wire safely goes through the hole.
    FixBot'a Sor
    Yorum Ekle
  3. Nest x Yale Lock Keypad Replacement: adım 3, 1 resimden 1.
    • Then once again unscrew the two screws that you see.
    • The screws have a height of 0.2 inches phillips screws.
    FixBot'a Sor
    Yorum Ekle
  4. Nest x Yale Lock Keypad Replacement: adım 4, 2 resimden 1. Nest x Yale Lock Keypad Replacement: adım 4, 2 resimden 2.
    • Once all screws are unscrewed proceed to tap the screen out of the metal casing.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Christopher Gonzalez
313 İtibar
3 adet Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 5-3, Adachi Fall 2022 CSU Los Angeles, Team 5-3, Adachi Fall 2022 üyesi
CSULA-ADACHI-F22S5G3
5 Üyeler
5 adet Kılavuz yazıldı
1Rehber Yorum
Where do you order the touchscreen from?
Mike Turrell - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 43
Her zaman: 703
