Ana içeriğe geç
Nest x Yale Lock Motherboard Replacement
Neye ihtiyacın var
  1. Nest x Yale Lock Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Before proceeding, make sure the batteries are removed to avoid being electrocuted and damage to the lock
    • If you do not know how to remove the batteries then I would recommend looking at our battery replacement guide for help.
  2. Nest x Yale Lock Motherboard Replacement: adım 2, 2 resimden 1. Nest x Yale Lock Motherboard Replacement: adım 2, 2 resimden 2.
    • Remove 3 screws as shown to remove the first cover.
    • The 3 screws are 0.25 inches length
  3. Nest x Yale Lock Motherboard Replacement: adım 3, 1 resimden 1.
    • Using a pin to push down the knot holding the wire and the tweezer to safely remove the wire from the motherboard
  4. Nest x Yale Lock Motherboard Replacement: adım 4, 2 resimden 1. Nest x Yale Lock Motherboard Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use a spudger or plastic tool to lift the ZIF lock upward (as shown in the first picture).
    • Use tweezers to remove the ribbon cable from the motherboard.
  5. Nest x Yale Lock Motherboard Replacement: adım 5, 1 resimden 1.
    • Continue to remove 2 screws holding the motherboard to the lock shell.
    • The screws are 0.20 inches in length.
  6. Nest x Yale Lock Motherboard Replacement: adım 6, 2 resimden 1. Nest x Yale Lock Motherboard Replacement: adım 6, 2 resimden 2.
    • Use an opening tool to push the motherboard out as shown in the picture.
Sonuç
Bryant Duong
379 İtibar
2 adet Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 5-3, Adachi Fall 2022 CSU Los Angeles, Team 5-3, Adachi Fall 2022 üyesi
CSULA-ADACHI-F22S5G3
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 14
Her zaman: 400
