Ana içeriğe geç
Nest x Yale Lock Speaker Replacement
Neye ihtiyacın var
  1. Nest x Yale Lock Speaker Replacement, Speaker: adım 1, 3 resimden 1. Nest x Yale Lock Speaker Replacement, Speaker: adım 1, 3 resimden 2. Nest x Yale Lock Speaker Replacement, Speaker: adım 1, 3 resimden 3.
    • Get the lock device and turn it around.
    • Take out the black cover by removing the screws as shown in picture #1 and pull it out gently just so.
    • All 3 screws are 0.25 inches high and are phillip screws.
    • Doing so gains access to the motherboard as shown in picture #3.
  2. Nest x Yale Lock Speaker Replacement: adım 2, 2 resimden 1. Nest x Yale Lock Speaker Replacement: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • On the white connector in picture #1, push down using a pointed tip object and then remove the connection using tweezers.
    • For the wider connection in picture #2, lift up the black switch and remove the connection using tweezers.
  3. Nest x Yale Lock Speaker Replacement: adım 3, 2 resimden 1. Nest x Yale Lock Speaker Replacement: adım 3, 2 resimden 2.
    • Take out the motherboard by unscrewing the screws holding it shown in picture #1.
    • The screws are phillips and are 0.25 inches.
    • After removing the screw on the motherboard, pry the motherboard out using a prying tool shown in picture #2.
  4. Nest x Yale Lock Speaker Replacement: adım 4, 1 resimden 1.
    • The small black part on the down right side of the motherboard is the audio.
Sonuç
Christopher Gonzalez
313 İtibar
3 adet Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 5-3, Adachi Fall 2022 CSU Los Angeles, Team 5-3, Adachi Fall 2022 üyesi
CSULA-ADACHI-F22S5G3
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 6
Son 30 gün: 16
Her zaman: 263
