Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Lift up all four rubber pads on the bottom of the router with the plastic opening tool.
Unscrew the four 11.8 mm T-8 torx screws from the bottom of the router.
Remove the clear plastic casing by lifting it straight up from the router.
Separate the motherboard from the top shell by lifting it straight up from the router.
Refer to this link for proper de-soldering and soldering techniques.
Peel off the yellow tape holding the wires.
Set the tape aside on a clean surface so that it can be reused.
Locate the clips that hold the antenna onto the router.
3 farklı kişi bu kılavuzu tamamladı.
