Ana içeriğe geç
NeuTab Air7 Battery Replacement
Neye ihtiyacın var
  1. NeuTab Air7 Battery Replacement, Back Cover: adım 1, 3 resimden 1. NeuTab Air7 Battery Replacement, Back Cover: adım 1, 3 resimden 2. NeuTab Air7 Battery Replacement, Back Cover: adım 1, 3 resimden 3.
    • Ensure your device is powered off before you begin.
    • Use the opening tool to gently pry the back cover off of the tablet, running it along the perimeter of the device.
    FixBot'a Sor
    Yorum Ekle
  2. NeuTab Air7 Battery Replacement, Battery: adım 2, 2 resimden 1. NeuTab Air7 Battery Replacement, Battery: adım 2, 2 resimden 2.
    • The following instructions require soldering, which can risk burn injuries as well as component damage for those novice in the skill. Tread with caution.
    • For a guide on how to solder, click here.
    • Remove any adhesive tape that is holding the wires protruding from the battery down.
    • De-solder the red and black wire ends that connect the battery to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  3. NeuTab Air7 Battery Replacement: adım 3, 2 resimden 1. NeuTab Air7 Battery Replacement: adım 3, 2 resimden 2.
    • Using metal tools can cause damage to the battery and potentially create a fire hazard. ESD safe tools are recommended for this operation.
    • Wedge a plastic or nylon spudger underneath the battery, moving it back and forth to separate it from the device.
    • Remove the battery.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Jason Soares
532 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2023 UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2023 üyesi
UMASSD-GULBRANDSEN-F23S2G1
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 30
Her zaman: 423
