Ana içeriğe geç
NeuTab Air7 Motherboard Replacement
Neye ihtiyacın var
  1. NeuTab Air7 Motherboard Replacement, Back Cover: adım 1, 3 resimden 1. NeuTab Air7 Motherboard Replacement, Back Cover: adım 1, 3 resimden 2. NeuTab Air7 Motherboard Replacement, Back Cover: adım 1, 3 resimden 3.
    • Ensure your device is powered off before you begin.
    • Use the opening tool to gently pry the back cover off of the tablet, running it along the perimeter of the device.
    FixBot'a Sor
    Yorum Ekle
  2. NeuTab Air7 Motherboard Replacement, Motherboard: adım 2, 2 resimden 1. NeuTab Air7 Motherboard Replacement, Motherboard: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Remove any adhesive tape attached to the motherboard.
    • Detach the connecting ribbons on the motherboard using tweezers or your fingers.
    FixBot'a Sor
    Yorum Ekle
  3. NeuTab Air7 Motherboard Replacement: adım 3, 2 resimden 1. NeuTab Air7 Motherboard Replacement: adım 3, 2 resimden 2.
    • The following instructions require soldering, which can risk burn injuries as well as component damage to those novice in the skill. Tread with caution.
    • For a guide on how to solder, click here.
    • De-solder all wires connected to the motherboard to sever the connections.
    FixBot'a Sor
    Yorum Ekle
  4. NeuTab Air7 Motherboard Replacement: adım 4, 3 resimden 1. NeuTab Air7 Motherboard Replacement: adım 4, 3 resimden 2. NeuTab Air7 Motherboard Replacement: adım 4, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove all three 0.8 screws holding the motherboard in place.
    • Remove the motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Jason Soares
532 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2023 UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2023 üyesi
UMASSD-GULBRANDSEN-F23S2G1
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 327
