Ana içeriğe geç
NeuTab Air7 Motherboard Replacement
Neye ihtiyacın var
  1. NeuTab Air7 Motherboard Replacement, Back Cover: adım 1, 3 resimden 1. NeuTab Air7 Motherboard Replacement, Back Cover: adım 1, 3 resimden 2. NeuTab Air7 Motherboard Replacement, Back Cover: adım 1, 3 resimden 3.
    • Ensure your device is powered off before you begin.
    • Use the opening tool to gently pry the back cover off of the tablet, running it along the perimeter of the device.
  2. NeuTab Air7 Motherboard Replacement, Motherboard: adım 2, 2 resimden 1. NeuTab Air7 Motherboard Replacement, Motherboard: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove any adhesive tape attached to the motherboard.
    • Detach the connecting ribbons on the motherboard using tweezers or your fingers.
  3. NeuTab Air7 Motherboard Replacement: adım 3, 2 resimden 1. NeuTab Air7 Motherboard Replacement: adım 3, 2 resimden 2.
    • The following instructions require soldering, which can risk burn injuries as well as component damage to those novice in the skill. Tread with caution.
    • For a guide on how to solder, click here.
    • De-solder all wires connected to the motherboard to sever the connections.
  4. NeuTab Air7 Motherboard Replacement: adım 4, 3 resimden 1. NeuTab Air7 Motherboard Replacement: adım 4, 3 resimden 2. NeuTab Air7 Motherboard Replacement: adım 4, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove all three 0.8 screws holding the motherboard in place.
    • Remove the motherboard.
Sonuç
Jason Soares
532 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2023 UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2023 üyesi
UMASSD-GULBRANDSEN-F23S2G1
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 152
