Ana içeriğe geç
NeuTab N7 Pro Battery Replacement
Neye ihtiyacın var
  1. NeuTab N7 Pro Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Power off your device before beginning disassembly.
    • Insert plastic opening tool and pry back case away from the device, slowly moving the plastic opening tool along the device.
  2. NeuTab N7 Pro Battery Replacement: adım 2, 1 resimden 1.
    • Follow the red and black wires from the battery to where they are soldered to the motherboard.
    • Warning: Use caution when handling a soldering iron to avoid injury or damage.
    • Use a soldering iron to separate the positive and negative wires from the motherboard.
    • For a complete guide on how to solder, click here.
  3. NeuTab N7 Pro Battery Replacement: adım 3, 2 resimden 1. NeuTab N7 Pro Battery Replacement: adım 3, 2 resimden 2.
    • Insert plastic spudger under the battery and slide back and forth, separating the battery from the case.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Eric Fiske
430 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 7-1, Cheng Spring 2016 USF Tampa, Team 7-1, Cheng Spring 2016 üyesi
USFT-CHENG-S16S7G1
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 2,019
