Giriş
If your speaker is not working or starting to go out then this guide is for you. By following the steps provided, you will be able to successfully replace the speaker for your NeuTab N7 Pro.
Neye ihtiyacın var
Insert plastic opening tool and pry back case away from the device, slowly moving the plastic opening tool along the device.
Bir başkası bu kılavuzu tamamladı.
