Ana içeriğe geç
New Nintendo 2DS XL Battery Replacement
Neye ihtiyacın var
  1. New Nintendo 2DS XL Battery Replacement, Back Cover Removal Preparation: adım 1, 1 resimden 1.
    • Before starting the disassembly, remove
    • The stylus
    • Any game cartridge
    • The SD card
    This is a great repair instructional, but I would advise also looking at the below video link. (I used both.) Sometimes watching 2 repair guides can help when you think you think you’re stuck. For example, I had a really hard time getting the hinge off!
    https://www.youtube.com/watch?v=Zuu_T2ls...
    (HINT: Works best if you rotate it 180 degrees, so that you are repairing it from the same perspective as the technician)
    skat1140 - Yanıt
  2. New Nintendo 2DS XL Battery Replacement, Back Cover Removal: adım 2, 1 resimden 1.
    • Unscrew the four 6mm tri-point screws located at the four corners of the bottom panel.
    The Y0 was too big; I ended up using a Y00 and that worked fine
    Christopher Gilmer-Hill - Yanıt
    Would not recommend using a Y000 like I tried to do
    Daniela Magaña-Ochoa - Yanıt
    gotta use Japanese Industry Standard YOO (blunt end)- I did not, and accidentally stripped two of the screws… still trying to figure out how to remove them -_-;
    Yanko Artidiello - Yanıt
    Yeah I can confirm, the y0 does not work.
    Arc Turus - Yanıt
    I'm using the Y-0.6 and seems to only unscrew 2 of the screws on the right side of the handheld, the other 2 aren't moving
    Xx_Definity_J0rd4n_xX - Yanıt
    screws are too tight
    Albert Einstien - Yanıt
  3. New Nintendo 2DS XL Battery Replacement, Case Separation: adım 3, 2 resimden 1. New Nintendo 2DS XL Battery Replacement, Case Separation: adım 3, 2 resimden 2.
    • Be careful when separating the bottom panel from the front casing to avoid breaking the three cables connected to the motherboard (two on each side and one in the rear).
    • Using a spudger, separate the back panel from the front casing by gently prying around the panel.
    • There are many clips along the hinge of the case, so it is recommended to work your way along one short side and the two long sides before finishing the last short side.
    You need to be super careful separating the top from the bottom at the rear end. I got stuck there, applied a lil more force and ripped the right shoulder button straight off the pcb!
    Dominik Leicht - Yanıt
    The front headphone Jack got stuck in the bottom case and snapped when opening, didn’t notice until after replacing the battery (which is a nightmare btw) I used some floss underneath the battery to give you better leverage since the side plastic is so thin and fragile. I cannot get the headphone Jack back into position now and will have to take it to a shop for (I’m sure much more expensive) repairs. Honestly DO NOT try repair this thing, just pay someone else to repair these. Compared to the OG 2011 3DS these are a nightmare to work with. Nintendo really went out of their way to make this impossible to repair, I had an extra set of pretty capable hands too.
    radioactiverhino 04 - Yanıt
    I also ripped off the headphone jack when taking the case apart. I never pulled hard. You need to be careful to give the headphone jack clearance before applying any force.
    Mikaela Orbon - Yanıt
  4. New Nintendo 2DS XL Battery Replacement: adım 4, 3 resimden 1. New Nintendo 2DS XL Battery Replacement: adım 4, 3 resimden 2. New Nintendo 2DS XL Battery Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Using tweezers, disconnect the two cables that connect the rear buttons on either side to the motherboard by gently pulling them upwards.
    I unfortunately took off the base of one when trying to pull apart. Is there a fix or will it not be broken?
    Phoenix Typhoon - Yanıt
    Did you manage to fix this at all?
    Owen McKay -
    When you are putting these cables back, make sure to check the orientation of the cable. You have to match the cable head to the entry point, so you may have to turn the cable around. I spent a bit too much time trying to connect the cables just because I didn't realize that I had to turn the cable around.
    Hongda Wang - Yanıt
    Aren't these the speaker cables? I haven't taken any 2DS's apart in a while, but I'm pretty sure these cables connect to the speakers
    darth mango - Yanıt
  5. New Nintendo 2DS XL Battery Replacement, Battery Removal: adım 5, 2 resimden 1. New Nintendo 2DS XL Battery Replacement, Battery Removal: adım 5, 2 resimden 2.
    • Using a spudger, lift out the battery.
    • Be aware that there is a sticky pad holding the battery into its tray. It may be necessary to use multiple tools to gently pry the battery away from the tray and motherboard.
    Some might see this as an optional step. But you probably do NOT want to skip this. I did, and now I have malfunctions on the Nintendo (touch screen functionality not working, possibly as a result of shorts from skipping this step.)
    skat1140 - Yanıt
    Personally, I skipped this step and everything still works fine. I wasn't able to take the battery out because the adhesive was too strong.
    Hongda Wang - Yanıt
    Small square of adhesive. Pull up slowly and it’ll release after 10-20 seconds
    Jacob Cocanig - Yanıt
    Any advise for dealing with CTR-003 spicy pillow? So far in this transplant operation, both my devices batteries are okay... but... I dunno, if I were to run into a spicy pillow in the future, what would be the least awful way to pull it out?
    Not sorry, when I see these repair jobs that involve the company gluing the battery into the device (or even soddering in that soon to be spicy pillow) this is just something I'm wondering about
    Katrina Payne - Yanıt
    I haven't taken my 2ds apart yet, depending on how devices are built it might work to slide a solid thread (eg fishing rope, or floss but that might rip) under it, and do a sewing motion.
    Franziska (Natsu) -
    Be careful when putting the clamshell back together. The plastic volume slider likes to fall out. if not aligned correctly, you may snap off the actual slider and be unable to physic change the volume
    Daniel Adezio - Yanıt
Sonuç
41 farklı kişi bu kılavuzu tamamladı.
Tim Newman
1.835 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G6, Forte Fall 2017 Cal Poly, Team S18-G6, Forte Fall 2017 üyesi
CPSU-FORTE-F17S18G6
5 Üyeler
20 adet Kılavuz yazıldı
14Kılavuz Yorumları
Does the 2ds xl have the same as the new 3ds xl
Royce davenport - Yanıt
no. the 2ds shares the same battery type as the Nintendo DS and the Nintendo switch pro controller.
Jason -
CTR-003 Battery
stephen cheshire - Yanıt
Do I need to put a sticky pad on the new battery?
bryan sepulveda - Yanıt
Got the exact screwdriver (Y00 / 1.5 x 50mm) but it doesn‘t fit. What are my options?
Maurice Willems - Yanıt
Get the one that fits: y0
Nick Bazin -
I just bought a Y0 because of this comment and I ended up stripping the screwdriver.
FelisLupus -
It appears that the SPR-003 battery is no longer stocked by Nintendo, and hasn't been for at least the last ~12 months or so - I'm uncertain where we might be able to find a reputable OEM these days for them, as it's not like we can trust something like amazon reviews anymore (if ever we could).
Would be great if iFixit could work on stocking something 'near-OEM' like they do with the DS / DS Lite so we'd have a trusted place to buy them from!
BVD - Yanıt
Based on the teardown, the 2DS XL uses the CTR-003 battery, not the SPR-003 in the 3DS XL.
Nick Schultz -
Be careful not to rip off the headphone jack when taking the case apart.
Great guide, though I must stress patience. Also, if the volume slider happens to fall out/shift, as happened to me, make sure to set the actual volume switch in a position where the (in this case blue) plastic piece will catch it in the 'U' shaped trough when the shell is closed up again.
Ryan Kruger - Yanıt
This does not take 3 minutes, nor is it that easy! Specifically, getting the shell off is a real pain, even with a prying tool. I ended up cracking the plastic too, which is a real shame since getting a replacement is quite difficult (or you get a crappy third party one). I think this guide should have a video.
Matvey Polishchuk - Yanıt
update: my brand new ifixit spudger tool just broke from doing this! The tip is now stuck between the shell and the device. Maybe I'm just not handy at all, but this isn't feeling worth it anymore!
Matvey Polishchuk -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 73
Son 7 gün: 545
Son 30 gün: 2,324
Her zaman: 87,902
