Ana içeriğe geç
New Nintendo 2DS XL Front Buttons Replacement
Neye ihtiyacın var
  1. New Nintendo 2DS XL Front Buttons Replacement, Prepare for disassembly: adım 1, 1 resimden 1.
    • Before you begin, power off the console and remove:
    • The stylus
    • Any game cartridge
    • The microSD card
    FixBot'a Sor
    Yorum Ekle
  2. New Nintendo 2DS XL Front Buttons Replacement, Remove the back cover screws: adım 2, 1 resimden 1.
    • Use a tri‑point Y00 screwdriver to remove the four 6 mm‑long screws located at the four corners of the bottom panel.
    FixBot'a Sor
    Yorum Ekle
  3. New Nintendo 2DS XL Front Buttons Replacement, Release the back cover clips: adım 3, 2 resimden 1. New Nintendo 2DS XL Front Buttons Replacement, Release the back cover clips: adım 3, 2 resimden 2.
    • Use a spudger to gently pry around the two short edges and front edge (with the stylus cut‑out) to release the clips securing the back cover.
    • Swing the back cover open from its front edge to release the clips along the hinge edge. Don't remove it fully—three cables are connecting it to the motherboard (two on each side and one in the rear).
    FixBot'a Sor
    Yorum Ekle
  4. New Nintendo 2DS XL Front Buttons Replacement, Disconnect the back cover: adım 4, 3 resimden 1. New Nintendo 2DS XL Front Buttons Replacement, Disconnect the back cover: adım 4, 3 resimden 2. New Nintendo 2DS XL Front Buttons Replacement, Disconnect the back cover: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers to disconnect the two cables that connect the rear buttons on either side to the motherboard by gently pulling them upwards.
    • Fold the back cover over the hinge edge, keeping the cable connected. Don't strain the cable.
    FixBot'a Sor
    Yorum Ekle
  5. New Nintendo 2DS XL Front Buttons Replacement, Battery Removal: adım 5, 2 resimden 1. New Nintendo 2DS XL Front Buttons Replacement, Battery Removal: adım 5, 2 resimden 2.
    • The battery is lightly adhered to its enclosure.
    • Use the flat end of a spudger to gently pry the battery out of its plastic enclosure.
    FixBot'a Sor
    Yorum Ekle
  6. New Nintendo 2DS XL Front Buttons Replacement, Motherboard: adım 6, 2 resimden 1. New Nintendo 2DS XL Front Buttons Replacement, Motherboard: adım 6, 2 resimden 2.
    • There are 8 ribbon cables that need to be removed as shown in the picture.
    • 2 of connectors (in green) are friction fit, unlike the rest of the connectors. Remove the cable by pulling it out gently flat in the arrow direction. Do not attempt to open or unlatch these connectors in any way. Doing so will break them.
    • For the remaining 6 (in red), use a pair of tweezers to flip the latches up and pull the ribbon cable out.
    • Note that the second picture shows a broken ribbon connector next to the joystick ribbon connector (to the right of the red arrow). Do not attempt to unlatch this connector as shown in the picture!
    FixBot'a Sor
    Yorum Ekle
  7. New Nintendo 2DS XL Front Buttons Replacement: adım 7, 2 resimden 1. New Nintendo 2DS XL Front Buttons Replacement: adım 7, 2 resimden 2.
    • Unplug the following wires from the motherboard using a pair of tweezers.
    FixBot'a Sor
    Yorum Ekle
  8. New Nintendo 2DS XL Front Buttons Replacement: adım 8, 2 resimden 1. New Nintendo 2DS XL Front Buttons Replacement: adım 8, 2 resimden 2.
    • Remove the seven 4.4 mm screws using a J00 (or iFixit's Phillips #00) screwdriver bit.
    • Remove the motherboard from the device.
    FixBot'a Sor
    Yorum Ekle
  9. New Nintendo 2DS XL Front Buttons Replacement, Button Removal: adım 9, 3 resimden 1. New Nintendo 2DS XL Front Buttons Replacement, Button Removal: adım 9, 3 resimden 2. New Nintendo 2DS XL Front Buttons Replacement, Button Removal: adım 9, 3 resimden 3.
    • Lift off the rubber cover on the A, B, X, and Y buttons.
    • Using tweezers, lift out the buttons.
    FixBot'a Sor
    Yorum Ekle
  10. New Nintendo 2DS XL Front Buttons Replacement: adım 10, 3 resimden 1. New Nintendo 2DS XL Front Buttons Replacement: adım 10, 3 resimden 2. New Nintendo 2DS XL Front Buttons Replacement: adım 10, 3 resimden 3.
    • Lift off the grey rubber cover on the start and select buttons.
    FixBot'a Sor
    Yorum Ekle
  11. New Nintendo 2DS XL Front Buttons Replacement: adım 11, 3 resimden 1. New Nintendo 2DS XL Front Buttons Replacement: adım 11, 3 resimden 2. New Nintendo 2DS XL Front Buttons Replacement: adım 11, 3 resimden 3.
    • Lift off the grey rubber membrane on the D-pad.
    • Using tweezers, lift the D-pad out.
    FixBot'a Sor
    Yorum Ekle
  12. New Nintendo 2DS XL Front Buttons Replacement: adım 12, 3 resimden 1. New Nintendo 2DS XL Front Buttons Replacement: adım 12, 3 resimden 2. New Nintendo 2DS XL Front Buttons Replacement: adım 12, 3 resimden 3.
    • Lift off the grey rubber membrane covering the home button.
    • Using tweezers, lift out the button.
    FixBot'a Sor
    Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Tim Newman
2.051 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G6, Forte Fall 2017 Cal Poly, Team S18-G6, Forte Fall 2017 üyesi
CPSU-FORTE-F17S18G6
5 Üyeler
24 adet Kılavuz yazıldı
4Kılavuz Yorumları
after assembly, pressing ZL causes some kind of an electric short, and the console turns off immediately, help !
mos_boum - Yanıt Paylaş
This usually occurs when you break the lower screen's power ribbon cable connector. It is not a ZIF connector and "unlatching" it will break it causing a loose fit. The shoulder button presses against the ribbon cable causing it to shift in the connector resulting in the speakers popping and the device turning off.
Mike - Yanıt Paylaş
OK. Lets say I can now change the buttons for replacement purposes only. My question is :where on the earth i can find buttons to replace??????
Robert - Yanıt Paylaş
Now there is a full set of keys for 2dsxl. If you can't find it, you can google kasynparts
kasynlife - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 75
Son 30 gün: 399
Her zaman: 21,304
