Ana içeriğe geç
Nextbook Premium 7SE Battery Replacement
Neye ihtiyacın var
    1. Nextbook Premium 7SE Battery Replacement, Back Cover: adım 1, 3 resimden 1. Nextbook Premium 7SE Battery Replacement, Back Cover: adım 1, 3 resimden 2. Nextbook Premium 7SE Battery Replacement, Back Cover: adım 1, 3 resimden 3.
      • Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers.
      • Slide the opening tool to the right and slowly continue to separate the back cover from the device.
      • Avoid prying on the buttons, as they are easily damaged.
      FixBot'a Sor
      Yorum Ekle
    2. Nextbook Premium 7SE Battery Replacement: adım 2, 1 resimden 1.
      • Pull the cover off of the device once about three quarters of the cover has been pried open using the plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    1. Nextbook Premium 7SE Battery Replacement, Battery: adım 3, 1 resimden 1.
      • Remove masking tape from the battery.
      FixBot'a Sor
      Yorum Ekle
    2. Nextbook Premium 7SE Battery Replacement: adım 4, 3 resimden 1. Nextbook Premium 7SE Battery Replacement: adım 4, 3 resimden 2. Nextbook Premium 7SE Battery Replacement: adım 4, 3 resimden 3.
      • Pry the battery from the base using the nylon spudger and move it away from the motherboard.
      • Handle the battery with care to avoid damaging it.
      FixBot'a Sor
      Yorum Ekle
    3. Nextbook Premium 7SE Battery Replacement: adım 5, 3 resimden 1. Nextbook Premium 7SE Battery Replacement: adım 5, 3 resimden 2. Nextbook Premium 7SE Battery Replacement: adım 5, 3 resimden 3.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order, being careful when re-soldering the contacts back into place.
Bir başkası bu kılavuzu tamamladı.
Walker Karstens
364 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-1, Williams Fall 2016 Baylor, Team 4-1, Williams Fall 2016 üyesi
BU-WILLIAMS-F16S4G1
4 Üyeler
28 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 1,029
