Ana içeriğe geç
Nextbook Premium 7SE Battery Replacement
Neye ihtiyacın var
  1. Nextbook Premium 7SE Battery Replacement, Back Cover: adım 1, 3 resimden 1. Nextbook Premium 7SE Battery Replacement, Back Cover: adım 1, 3 resimden 2. Nextbook Premium 7SE Battery Replacement, Back Cover: adım 1, 3 resimden 3.
    • Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers.
    • Slide the opening tool to the right and slowly continue to separate the back cover from the device.
    • Avoid prying on the buttons, as they are easily damaged.
  2. Nextbook Premium 7SE Battery Replacement: adım 2, 1 resimden 1.
    • Pull the cover off of the device once about three quarters of the cover has been pried open using the plastic opening tool.
  3. Nextbook Premium 7SE Battery Replacement, Battery: adım 3, 1 resimden 1.
    • Remove masking tape from the battery.
  4. Nextbook Premium 7SE Battery Replacement: adım 4, 3 resimden 1. Nextbook Premium 7SE Battery Replacement: adım 4, 3 resimden 2. Nextbook Premium 7SE Battery Replacement: adım 4, 3 resimden 3.
    • Pry the battery from the base using the nylon spudger and move it away from the motherboard.
    • Handle the battery with care to avoid damaging it.
  5. Nextbook Premium 7SE Battery Replacement: adım 5, 3 resimden 1. Nextbook Premium 7SE Battery Replacement: adım 5, 3 resimden 2. Nextbook Premium 7SE Battery Replacement: adım 5, 3 resimden 3.
    • De-solder the three contact points and remove the battery.
    • See the following guide for instructions on how to solder. How To Solder and Desolder Connections
    • Use caution when operating the soldering iron.
Sonuç
To reassemble your device, follow these instructions in reverse order, being careful when re-soldering the contacts back into place.
Bir başkası bu kılavuzu tamamladı.
Walker Karstens
364 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-1, Williams Fall 2016 Baylor, Team 4-1, Williams Fall 2016 üyesi
BU-WILLIAMS-F16S4G1
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 710
