Ana içeriğe geç
Nextbook Premium 7SE Replace Power Button Replacement
Neye ihtiyacın var
    1. Nextbook Premium 7SE Replace Power Button Replacement, Back Cover: adım 1, 3 resimden 1. Nextbook Premium 7SE Replace Power Button Replacement, Back Cover: adım 1, 3 resimden 2. Nextbook Premium 7SE Replace Power Button Replacement, Back Cover: adım 1, 3 resimden 3.
      • Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers.
      • Slide the opening tool to the right and slowly continue to separate the back cover from the device.
      • Avoid prying on the buttons, as they are easily damaged.
      FixBot'a Sor
      Yorum Ekle
    2. Nextbook Premium 7SE Replace Power Button Replacement: adım 2, 1 resimden 1.
      • Pull the cover off of the device once about three quarters of the cover has been pried open using the plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    1. Nextbook Premium 7SE Replace Power Button Replacement, Battery: adım 3, 1 resimden 1.
      • Remove masking tape from the battery.
      FixBot'a Sor
      Yorum Ekle
    2. Nextbook Premium 7SE Replace Power Button Replacement: adım 4, 3 resimden 1. Nextbook Premium 7SE Replace Power Button Replacement: adım 4, 3 resimden 2. Nextbook Premium 7SE Replace Power Button Replacement: adım 4, 3 resimden 3.
      • Pry the battery from the base using the nylon spudger and move it away from the motherboard.
      • Handle the battery with care to avoid damaging it.
      FixBot'a Sor
      Yorum Ekle
    3. Nextbook Premium 7SE Replace Power Button Replacement: adım 5, 3 resimden 1. Nextbook Premium 7SE Replace Power Button Replacement: adım 5, 3 resimden 2. Nextbook Premium 7SE Replace Power Button Replacement: adım 5, 3 resimden 3.
      FixBot'a Sor
      Yorum Ekle
    1. Nextbook Premium 7SE Replace Power Button Replacement, Motherboard: adım 6, 3 resimden 1. Nextbook Premium 7SE Replace Power Button Replacement, Motherboard: adım 6, 3 resimden 2. Nextbook Premium 7SE Replace Power Button Replacement, Motherboard: adım 6, 3 resimden 3.
      • Remove the two ZIF connectors attached to the motherboard by flipping up the black tabs before pulling the ribbon cable away.
      • Only use a fingernail or nylon spudger to flip up the retaining flap. Using metal tools may damage delicate components.
      FixBot'a Sor
      Yorum Ekle
    2. Nextbook Premium 7SE Replace Power Button Replacement: adım 7, 1 resimden 1.
      • Use the nut driver and J00 bit to remove the three 4 mm screws.
      FixBot'a Sor
      Yorum Ekle
    3. Nextbook Premium 7SE Replace Power Button Replacement: adım 8, 3 resimden 1. Nextbook Premium 7SE Replace Power Button Replacement: adım 8, 3 resimden 2. Nextbook Premium 7SE Replace Power Button Replacement: adım 8, 3 resimden 3.
      • Peel back metal tape that is hiding the auxiliary port wires.
      • Remove tape that is holding the speaker wires in place.
      • Lift up on the motherboard to release it from the tablet.
      FixBot'a Sor
      Yorum Ekle
    1. Nextbook Premium 7SE Replace Power Button Replacement, Replace Power Button: adım 9, 1 resimden 1.
      • De-solder the power button's four contact points.
      • Follow this guide to learn how to desolder safely.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Michelle Helweh
214 İtibar
2 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-1, Williams Fall 2016 Baylor, Team 4-1, Williams Fall 2016 üyesi
BU-WILLIAMS-F16S4G1
4 Üyeler
28 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 29
Her zaman: 591
