Ana içeriğe geç
Nexus 5X Front-Facing Camera Replacement
Dominik Schnabelrauch
Dominik Schnabelrauch ve 7 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
15 - 20 dakika
Kolay
Use this guide to replace the front-facing camera in your Nexus 5X.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Nexus 5X Front-Facing Camera Replacement, SIM Card Tray: adım 1, 3 resimden 1. Nexus 5X Front-Facing Camera Replacement, SIM Card Tray: adım 1, 3 resimden 2. Nexus 5X Front-Facing Camera Replacement, SIM Card Tray: adım 1, 3 resimden 3.
    • Insert a SIM card ejection tool into the hole on the SIM card tray, located on the left edge of the phone.
    • Press in to eject the SIM card tray.
    • Remove the SIM card tray.
  2. Nexus 5X Front-Facing Camera Replacement, Rear Panel: adım 2, 3 resimden 1. Nexus 5X Front-Facing Camera Replacement, Rear Panel: adım 2, 3 resimden 2. Nexus 5X Front-Facing Camera Replacement, Rear Panel: adım 2, 3 resimden 3.
    • Place an opening pick in the opening of the SIM card tray slot and twist it sideways to release the first plastic clip that holds the rear panel in its place.
    • Slide the opening pick around the top edge of the phone to release the plastic clips that secure the rear panel.
  3. Nexus 5X Front-Facing Camera Replacement: adım 3, 3 resimden 1. Nexus 5X Front-Facing Camera Replacement: adım 3, 3 resimden 2. Nexus 5X Front-Facing Camera Replacement: adım 3, 3 resimden 3.
    • Continue to slide the opening pick around all sides of the phone to release all clips that secure the rear panel.
  4. Nexus 5X Front-Facing Camera Replacement: adım 4, 2 resimden 1. Nexus 5X Front-Facing Camera Replacement: adım 4, 2 resimden 2.
    • Tilt the opening pick to lift the rear panel a little bit.
    • There are two more plastic clips next to the fingerprint sensor. Release them by gently pulling the rear panel.
    • Remove the rear panel.
  5. Nexus 5X Front-Facing Camera Replacement, Midframe: adım 5, 1 resimden 1.
    • Remove the ten 3.6 mm Phillips screws that secure the midframe.
  6. Nexus 5X Front-Facing Camera Replacement: adım 6, 2 resimden 1. Nexus 5X Front-Facing Camera Replacement: adım 6, 2 resimden 2.
    • Insert an opening pick into the SIM card tray slot and twist the opening pick sideways to release the plastic clips.
  7. Nexus 5X Front-Facing Camera Replacement: adım 7, 2 resimden 1. Nexus 5X Front-Facing Camera Replacement: adım 7, 2 resimden 2.
    • Continue sliding the opening pick around the upper part of the midframe to release the plastic clips.
  8. Nexus 5X Front-Facing Camera Replacement: adım 8, 2 resimden 1. Nexus 5X Front-Facing Camera Replacement: adım 8, 2 resimden 2.
    • Use the plastic pick to pry open the plastic clips on the long edge of the midframe and on the bottom edge.
    • Make sure the clips on the long edge are released. The midframe is prone to break here if they are not disconnected properly.
  9. Nexus 5X Front-Facing Camera Replacement: adım 9, 2 resimden 1. Nexus 5X Front-Facing Camera Replacement: adım 9, 2 resimden 2.
    • Make sure all the clips are free.
    • Carefully remove the midframe.
  10. Nexus 5X Front-Facing Camera Replacement, Battery Disconnect: adım 10, 2 resimden 1. Nexus 5X Front-Facing Camera Replacement, Battery Disconnect: adım 10, 2 resimden 2.
    • Use the edge of a spudger to pry up and disconnect the battery flex cable located at the bottom right of the motherboard.
  11. Nexus 5X Front-Facing Camera Replacement, Front Facing Camera: adım 11, 2 resimden 1. Nexus 5X Front-Facing Camera Replacement, Front Facing Camera: adım 11, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the front-facing camera flex cable.
  12. Nexus 5X Front-Facing Camera Replacement: adım 12, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers to remove the front-facing camera from its recess.
Sonuç
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
Repair didn’t go as planned? Check out our Nexus 5X Answers community for troubleshooting help.
3 farklı kişi bu kılavuzu tamamladı.
231.292 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.670 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 2,299
