Giriş
This Nexus 5X replacement guide will show you how to replace only the LCD screen and digitizer on your Nexus 5X mobile device—not the screen assembly. If your replacement part includes the plastic frame, you will need to transfer additional parts (LED, vibration motor, ear speaker, headphone jack, power/volume buttons, and proximity sensor gaskets) to your new frame assembly. Be sure to read through the steps and comments carefully before you begin your replacement.
If your glass screen (digitizer) is cracked, damaged, or unresponsive to touch, this guide will help you replace the damaged glass screen and restore functionality to your device.
If your display has dead pixels, displays distorted or blurry images, or fails to display anything at all, this guide will help you replace the damaged LCD.
Adhesive strength and device condition may vary; please exercise caution when removing components from your device.
Neye ihtiyacın var
Insert a SIM card ejection tool into the hole on the SIM card tray, located on the left edge of the phone.
Press in to eject the SIM card tray.
Remove the SIM card tray.
Place an opening pick in the opening of the SIM card tray slot and twist it sideways to release the first plastic clip that holds the rear panel in its place.
Slide the opening pick around the top edge of the phone to release the plastic clips that secure the rear panel.
Use the edge of a spudger to pry up and disconnect the battery flex cable located at the bottom right of the motherboard.
Use an iOpener to loosen the adhesive beneath the battery. Apply the iOpener on the back of the phone for at least two minutes.
Insert the flat end of a spudger under the bottom left corner of the battery and gently pry upwards.
If you are having trouble prying up the battery, the adhesive may not be loose enough. You can apply some isopropyl alcohol under each corner of the battery and allow it to penetrate for several minutes to help weaken the adhesive.
Adım 15 Motherboard Assembly
Dikkatli ol: adımlar 15-18 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
Use an iOpener to loosen the adhesive beneath the rear facing camera. Place the iOpener across the top part of the phone for about 30 seconds.
Use an iOpener or a heat gun over the digitizer ribbon cable to soften the adhesive that secures it to the plastic housing.
Gently wedge the flat end of a spudger into the gap between the battery housing and the digitizer ribbon cable, or use your fingers to gently pull the digitizer ribbon cable free.
Bu adımda kullanılan alet:Heat Gun$24.99
Use an iOpener or a heat gun to soften the adhesive underneath the edges of the screen.
In case you're using a heat gun hold it approximately 8 inches from your screen, and apply heat along the edges in a gentle back-and-forth motion for roughly 2 minutes.
Bu adımda kullanılan alet:iFixit Opening Picks (Set of 6)$4.99
Insert a plastic opening pick into the gap between the screen and the plastic housing.
Slide the plastic opening pick along the border of the screen to free the screen from any remaining adhesive.
37 farklı kişi bu kılavuzu tamamladı.
23Kılavuz Yorumları
Good guide, but not the end all - this guide doesn't accurately reflect how difficult the cameras and battery can be to remove. Also, if you are replacing the LCD+digitizer+frame, you will need to remove the LED, headphone jack, and vibration motor
Hello Jay! Thank you for your comment. I've added some of the details you mentioned to help our readers. Guide specifics can vary since it's not always possible to judge the state of a reader's particular device, but that's the beauty of a repair wiki! We can all pitch in and create a comprehensive guide.
You are correct—additional components and/or parts may need to be transferred or removed depending on the replacement. You certainly can remove the LED panel, headphone jack, and vibration motor, but it is not required to free the LCD screen and digitizer in this guide. The cameras are removed in this guide due to their fragility and the potential for component damage during the replacement.
Always research replacement kits and parts before ordering, and make sure you've got everything you need for a successful repair!
Richard -
This guide helped tremendously, things got a little confusing after step 10 (my replacement screen came with the frame, which I think is the better option). As Jay Miley pointed out there are several other steps required for moving components from the old frame (and unfortunately it's easy to overlook some of the smaller pieces), but it was still nice to have this guide to reference.
Hiya Craig! I'm glad to hear that your replacement went well even though you had the +frame replacement part. There are two screen replacement options for the 5X; the +frame replacement part for the 5X requires additional components and gaskets to be transferred from your old frame. I'll try to get a guide up for the LCD & digitizer +frame replacement part in addition to this guide.
Richard -
I had a pre-assembled screen / frame so the only real difference was:
* heatgun and remove headphone jack
* power / volume buttons also needed to be switched over (very small flat head screw driver to pop-up)
