Ana içeriğe geç
Nexus Q LED Board Replacement
Neye ihtiyacın var
  1. Nexus Q LED Board Replacement, Ball Bearing Ring: adım 1, 1 resimden 1.
    • Squeeze and pull the cap to remove it from the Nexus Q.
    FixBot'a Sor
    Yorum Ekle
  2. Nexus Q LED Board Replacement: adım 2, 1 resimden 1.
    • Use a spudger to disconnect the Taoglas Wi-Fi Dual Band Antenna.
    FixBot'a Sor
    Yorum Ekle
  3. Nexus Q LED Board Replacement: adım 3, 1 resimden 1.
    • Undo the ZIF connector by prying it with a spudger.
    FixBot'a Sor
    Yorum Ekle
  4. Nexus Q LED Board Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #0 screwdriver to unscrew the four 1.3 mm screws.
    • After removing the screws, there will be two parts. The top part contains the daughterboard. Store it safely. It will not be used.
    FixBot'a Sor
    Yorum Ekle
  5. Nexus Q LED Board Replacement: adım 5, 1 resimden 1.
    • View the bottom half of the Nexus Q.
    • Use a Phillips #0 screwdriver to remove the four 0.8 mm screws holding the ball bearing ring in place.
    FixBot'a Sor
    Yorum Ekle
  6. Nexus Q LED Board Replacement: adım 6, 1 resimden 1.
    • Remove the ball bearing ring.
    • When placing a new ring in its place, make sure to orient it right or the top will not close.
    FixBot'a Sor
    Yorum Ekle
  7. Nexus Q LED Board Replacement, LED Board: adım 7, 2 resimden 1. Nexus Q LED Board Replacement, LED Board: adım 7, 2 resimden 2.
    • Once you remove the ball bearing ring from the bottom half of the Nexus Q, you will be exposed to a diffuser (white ring) held in with three T6 Torx screws.
    • Use a #0 Philips head screwdriver to remove the three 0.8 mm screws holding the diffuser in place.
    FixBot'a Sor
    Yorum Ekle
  8. Nexus Q LED Board Replacement: adım 8, 2 resimden 1. Nexus Q LED Board Replacement: adım 8, 2 resimden 2.
    • With the diffuser out, we are exposed to the LED Board.
    • Use a spudger to lightly lift the LED board out.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Taewan Kim
22 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-10, Maness Winter 2013 Cal Poly, Team 7-10, Maness Winter 2013 üyesi
CPSU-MANESS-W13S7G10
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 35
Her zaman: 834
