Ana içeriğe geç
Nikon COOLPIX P500 Image Sensor Replacement
Kevin Scott
Kevin Scott ve 5 diğer katkıda bulunanlar
En son October 10, 2023 tarihinde güncellendi
30 dakika - 2 saat
Zor
Tutarsız Görseller
Daha İyi Resimler Gerekli
This guide demonstrates how to remove the image sensor from your Nikon COOLPIX P500 camera.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Nikon COOLPIX P500 Image Sensor Replacement, Motherboard: adım 1, 3 resimden 1. Nikon COOLPIX P500 Image Sensor Replacement, Motherboard: adım 1, 3 resimden 2. Nikon COOLPIX P500 Image Sensor Replacement, Motherboard: adım 1, 3 resimden 3.
    • Remove all the marked screws using a PH00 screwdriver.
    • Remove the two 3mm screws on the grip.
    • Remove the two 4mm screws on the side opposite the grip.
    • Remove the three 4mm screws on the base of the camera.
    • Remove the four 3mm screws on the base of the camera.
  2. Nikon COOLPIX P500 Image Sensor Replacement, Removing hidden screws: adım 2, 2 resimden 1. Nikon COOLPIX P500 Image Sensor Replacement, Removing hidden screws: adım 2, 2 resimden 2.
    • Open the flash module of the camera.
    • Remove the 2mm screw from the microphone metal grid using a PH00 screwdriver.
    • Remove the 4mm screw that was under the metal microphone grid using a PH00 screwdriver.
  3. Nikon COOLPIX P500 Image Sensor Replacement: adım 3, 2 resimden 1. Nikon COOLPIX P500 Image Sensor Replacement: adım 3, 2 resimden 2.
    • Separate the two parts of the body of the camera slightly.
    • Release the two cables by lifting up their respective clips with a spudger.
    • Make sure not to pull too hard because there are connector ribbons.
    • Detach the connector ribbons before fully separating the camera into two pieces.
    • These pictures were taken after the connector ribbons were released and the camera was separated into two parts. You will need to release the connector ribbons while the camera is still in one piece before you can separate it like the pictures.
  4. Nikon COOLPIX P500 Image Sensor Replacement: adım 4, 1 resimden 1.
    • Use a spudger to flip up the cable lock in order to release the ribbon.
  5. Nikon COOLPIX P500 Image Sensor Replacement: adım 5, 2 resimden 1. Nikon COOLPIX P500 Image Sensor Replacement: adım 5, 2 resimden 2.
    • Use a PH00 screwdriver to unscrew the four labeled 3mm metal screws on the metal backing.
    • Remove the four labeled 4mm screws connected to the motherboard.
    • Remove the metal support.
  6. Nikon COOLPIX P500 Image Sensor Replacement: adım 6, 2 resimden 1. Nikon COOLPIX P500 Image Sensor Replacement: adım 6, 2 resimden 2.
    • Desolder the labeled soldering points.
    • Soldering irons are very hot. They can damage your device and inflict physical harm if proper care is not taken.
  7. Nikon COOLPIX P500 Image Sensor Replacement: adım 7, 2 resimden 1. Nikon COOLPIX P500 Image Sensor Replacement: adım 7, 2 resimden 2.
  8. Nikon COOLPIX P500 Image Sensor Replacement: adım 8, 3 resimden 1. Nikon COOLPIX P500 Image Sensor Replacement: adım 8, 3 resimden 2. Nikon COOLPIX P500 Image Sensor Replacement: adım 8, 3 resimden 3.
    • Use a spudger to unlock the labeled connector ribbons.
    • Disconnect the labeled connector ribbons.
  9. Nikon COOLPIX P500 Image Sensor Replacement: adım 9, 2 resimden 1. Nikon COOLPIX P500 Image Sensor Replacement: adım 9, 2 resimden 2.
    • Use a spudger to unlock the two connector ribbons.
    • Disconnect the two connector ribbons.
  10. Nikon COOLPIX P500 Image Sensor Replacement: adım 10, 1 resimden 1.
    • Remove the mother board from the camera.
  11. Nikon COOLPIX P500 Image Sensor Replacement, Image Sensor: adım 11, 1 resimden 1.
    • Use a PH00 screwdriver to remove the two 2mm metal screws from the image sensor cover.
  12. Nikon COOLPIX P500 Image Sensor Replacement: adım 12, 1 resimden 1.
    • Use a spudger to unlock the connector ribbon.
  13. Nikon COOLPIX P500 Image Sensor Replacement: adım 13, 1 resimden 1.
    • Use a PH00 screwdriver to remove the three 3mm screws holding the image sensor down.
  14. Nikon COOLPIX P500 Image Sensor Replacement: adım 14, 1 resimden 1.
    • Remove the image sensor.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Kevin Scott
517 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 19-10, Maness Winter 2015 Cal Poly, Team 19-10, Maness Winter 2015 üyesi
CPSU-MANESS-W15S19G10
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 45
Her zaman: 2,055
