Ana içeriğe geç
Nikon Coolpix 7900 Back Cover Replacement
Kaky Payne
Kaky Payne ve 7 diğer katkıda bulunanlar
En son June 14, 2020 tarihinde güncellendi
15 dakika
Orta
Öne Çıkan Kılavuzlar
Use this guide to replace the back cover.
Neye ihtiyacın var
Parçalar
  • Spudger
    Spudger
Aletler
Daha fazlasını göster…
  1. Nikon Coolpix 7900 Back Cover Replacement, Back Cover: adım 1, 1 resimden 1.
    • Remove the four 3.0mm screws on the bottom of the camera.
  2. Nikon Coolpix 7900 Back Cover Replacement: adım 2, 1 resimden 1.
    • Remove the two 3.0mm screws on the left side of the camera near the memory card compartment.
  3. Nikon Coolpix 7900 Back Cover Replacement: adım 3, 1 resimden 1.
    • Remove the two 3.0mm screws on the right side of the camera.
  4. Nikon Coolpix 7900 Back Cover Replacement: adım 4, 1 resimden 1.
    • Carefully open the back cover. Take care as there are connectors still attached.
  5. Nikon Coolpix 7900 Back Cover Replacement: adım 5, 1 resimden 1.
    • Disconnect the cable by pulling the head upward along the green circuit board. If you only are changing the LCD, skip this step.
  6. Nikon Coolpix 7900 Back Cover Replacement: adım 6, 1 resimden 1.
    • Disconnect the ribbon cable by grabbing the two handles and pulling it directly out of the socket. If you are only changing LCD, skip this step.
    • The back cover will be disconnected from the camera
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kaky Payne
121 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-38, Regan Spring 2012 Cal Poly, Team 12-38, Regan Spring 2012 üyesi
CPSU-REGAN-S12S12G38
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 14
Her zaman: 1,334
