Ana içeriğe geç
Nikon Coolpix AW130 Motherboard Replacement
Neye ihtiyacın var
  1. Nikon Coolpix AW130 Motherboard Replacement, Battery: adım 1, 2 resimden 1. Nikon Coolpix AW130 Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Motherboard Replacement: adım 2, 2 resimden 1. Nikon Coolpix AW130 Motherboard Replacement: adım 2, 2 resimden 2.
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Motherboard Replacement: adım 3, 1 resimden 1.
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 Motherboard Replacement: adım 4, 2 resimden 1. Nikon Coolpix AW130 Motherboard Replacement: adım 4, 2 resimden 2.
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 Motherboard Replacement, Front Panel: adım 5, 2 resimden 1. Nikon Coolpix AW130 Motherboard Replacement, Front Panel: adım 5, 2 resimden 2.
    • Using the T4 Torx Screwdriver, remove the 2, 4mm screws holding the N-Mark plate in place.
    • Carefully pull the plate off of the face.
  6. Nikon Coolpix AW130 Motherboard Replacement: adım 6, 2 resimden 1. Nikon Coolpix AW130 Motherboard Replacement: adım 6, 2 resimden 2.
    • Using the metal spudger tool, pry the colored face from the camera body.
    • Avoid bending or scratching the front face.
  7. Nikon Coolpix AW130 Motherboard Replacement, Back Panel: adım 7, 2 resimden 1. Nikon Coolpix AW130 Motherboard Replacement, Back Panel: adım 7, 2 resimden 2.
    • Using the T5 Torx screwdriver, remove all four 4mm screws.
  8. Nikon Coolpix AW130 Motherboard Replacement: adım 8, 1 resimden 1.
    • Using a Phillips #000 screwdriver, remove the single 3mm screw found inside the battery/charging compartment.
  9. Nikon Coolpix AW130 Motherboard Replacement: adım 9, 1 resimden 1.
    • Remove the upper cover (connected by glue) and unscrew the single Philips screw.
  10. Nikon Coolpix AW130 Motherboard Replacement: adım 10, 2 resimden 1. Nikon Coolpix AW130 Motherboard Replacement: adım 10, 2 resimden 2.
    • Remove two Philips screws from the bottom cover, lift gently the cover and remove the single Philips screw under it.
  11. Nikon Coolpix AW130 Motherboard Replacement: adım 11, 1 resimden 1.
    • Carefully remove the back cover from the camera body.
  12. Nikon Coolpix AW130 Motherboard Replacement, Motherboard: adım 12, 2 resimden 1. Nikon Coolpix AW130 Motherboard Replacement, Motherboard: adım 12, 2 resimden 2.
    • Using a Phillips #000 screwdriver, remove all 8, 4mm screws on the motherboard.
  13. Nikon Coolpix AW130 Motherboard Replacement: adım 13, 1 resimden 1.
    • Using the nylon spudger tool, peel back the metallic plate.
    • A metal spudger is shown in the photo, but a nylon spudger should be used.
    • Do not rip the gold-colored ribbons.
  14. Nikon Coolpix AW130 Motherboard Replacement: adım 14, 1 resimden 1.
    • Using your fingers, carefully disconnect the connector ribbons.
    • Though various guides suggest using a plastic or metal spudger tool to disconnect the ribbons, this tool is liable to damage the connectors.
  15. Nikon Coolpix AW130 Motherboard Replacement: adım 15, 1 resimden 1.
    • Carefully remove the black piece on the lefthand side.
  16. Nikon Coolpix AW130 Motherboard Replacement: adım 16, 1 resimden 1.
    • On the remaining piece, desolder the labeled soldering points.
    • The soldering tool can get extremely hot. For soldering help, check out iFixit's guide for How to Solder and Desolder Connections.
  17. Nikon Coolpix AW130 Motherboard Replacement: adım 17, 1 resimden 1.
    • Flip the remaining piece over, careful not to rip any of the connecting wires.
  18. Nikon Coolpix AW130 Motherboard Replacement: adım 18, 1 resimden 1.
    • Desolder at the prescribed sites.
    • Remove the motherboard from the camera body.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Thanks for this guide.
I managed to open 2 of theses and swap the sensor-unit from one to another.
Unluckily the camera remains broken since one only shows a black picture - even though the sensor is alright an the other has a broken AF from a fall, I suppose...
I am certain with some silicone grease on the orange rubber the camera would still be waterproof.
Daniel Bardua - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 9
Son 30 gün: 50
Her zaman: 5,495
