Ana içeriğe geç
Nikon Coolpix AW130 Shutter Button Replacement
Lauren Stepp
Lauren Stepp ve 2 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
15 dakika
Orta
The shutter button can oftentimes get caked with mud. Because it isn't fixed with screws or glue, it can also become stuck from constant use. Simply replacing the entire button, after removing the front panel and side buttons, is a simple fix.
Neye ihtiyacın var
Parçalar
Daha fazlasını göster…
  1. Nikon Coolpix AW130 Shutter Button Replacement, Battery: adım 1, 2 resimden 1. Nikon Coolpix AW130 Shutter Button Replacement, Battery: adım 1, 2 resimden 2.
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Shutter Button Replacement: adım 2, 2 resimden 1. Nikon Coolpix AW130 Shutter Button Replacement: adım 2, 2 resimden 2.
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Shutter Button Replacement: adım 3, 1 resimden 1.
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 Shutter Button Replacement: adım 4, 2 resimden 1. Nikon Coolpix AW130 Shutter Button Replacement: adım 4, 2 resimden 2.
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 Shutter Button Replacement, Front Panel: adım 5, 2 resimden 1. Nikon Coolpix AW130 Shutter Button Replacement, Front Panel: adım 5, 2 resimden 2.
    • Using the T4 Torx Screwdriver, remove the 2, 4mm screws holding the N-Mark plate in place.
    • Carefully pull the plate off of the face.
  6. Nikon Coolpix AW130 Shutter Button Replacement: adım 6, 2 resimden 1. Nikon Coolpix AW130 Shutter Button Replacement: adım 6, 2 resimden 2.
    • Using the metal spudger tool, pry the colored face from the camera body.
    • Avoid bending or scratching the front face.
  7. Nikon Coolpix AW130 Shutter Button Replacement, Shutter Button: adım 7, 2 resimden 1. Nikon Coolpix AW130 Shutter Button Replacement, Shutter Button: adım 7, 2 resimden 2.
    • Using your thumb, separate the top piece of plastic from the camera.
    • If this piece does not come loose easily, try using the nylon spudger.
  8. Nikon Coolpix AW130 Shutter Button Replacement: adım 8, 3 resimden 1. Nikon Coolpix AW130 Shutter Button Replacement: adım 8, 3 resimden 2. Nikon Coolpix AW130 Shutter Button Replacement: adım 8, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Using tweezers from the precision tweezer set, carefully loosen the shutter button.
    • Atop the camera, there are two buttons. The shutter button should be the largest of the two.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 1,181
