Ana içeriğe geç
Nikon Coolpix L32 LCD Replacement
Sherika Jacobs
Sherika Jacobs ve 4 diğer katkıda bulunanlar
En son June 26, 2020 tarihinde güncellendi
15 dakika
Zor
If the Nikon Coolpix L32 suffered from physical damages and it remains dark after trying to power it on, consider replacing the LCD Screen. No hazards are associated with this replacement.
Neye ihtiyacın var
Aletler
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  1. Nikon Coolpix L32 LCD Replacement, Front Panel: adım 1, 3 resimden 1. Nikon Coolpix L32 LCD Replacement, Front Panel: adım 1, 3 resimden 2. Nikon Coolpix L32 LCD Replacement, Front Panel: adım 1, 3 resimden 3.
    • Remove the six(3.93mm screws) on the outside of the camera using a Phillips 00 screwdriver.
  2. Nikon Coolpix L32 LCD Replacement: adım 2, 1 resimden 1.
    • Open the battery compartment door and pull the black back face apart from the front red face.
  3. Nikon Coolpix L32 LCD Replacement, LCD: adım 3, 1 resimden 1.
    • Using the spudger, gently pull the LCD screen from the tray holding it.
    • Do not pull the LCD screen far from the camera because there is a ribbon cable connected to it.
  4. Nikon Coolpix L32 LCD Replacement: adım 4, 1 resimden 1.
    • Use the spudger to lift up the small white retaining flap on the motherboard that is connected to the LCD screen's ribbon cable.
  5. Nikon Coolpix L32 LCD Replacement: adım 5, 1 resimden 1.
    • With the small retaining white flap up, remove the LCD screen ribbon cable from the motherboard by sliding it out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sherika Jacobs
348 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-4, Blackwell Fall 2016 USF Tampa, Team 2-4, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S2G4
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 893
