Nikon Coolpix L330 Back Housing Replacement
Giriş
1. adıma gitUse this guide to replace a scratched or damaged back plate.
This guide requires removing the back housing of the camera. When replacing the housing, use a PH000 screwdriver. The cover is well secured, so some force may be needed to remove the screws as well as the cover.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
There are six screws attaching the back housing to the camera. Remove the screws from the body with a PH000 screw head.
Two 1.5x2.5mm screws on the right side.
Two 1.5x2.5mm screws on the underside.
Two 1.5x2.5mm screw on the left side.
