Ana içeriğe geç
Nikon Coolpix L340 Battery Replacement
  1. Nikon Coolpix L340 Battery Replacement, Battery: adım 1, 2 resimden 1. Nikon Coolpix L340 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the camera so that the flash is facing downward- you are now looking at the bottom of the camera
    • If the camera lens its pointing towards you, there should be a small lever on the right hand side
    • Take this lever and push it away from your body, while simultaneously pulling upwards
  2. Nikon Coolpix L340 Battery Replacement: adım 2, 2 resimden 1. Nikon Coolpix L340 Battery Replacement: adım 2, 2 resimden 2.
    • Once you have pulled up, four batteries will appear underneith
    • Note how there are two batteries facing upwards (circled in red)
    • and two batteries facing downwards (circled in orange)
    • When the new batteries are placed back in the camera, they should be put back in this same orientation
  3. Nikon Coolpix L340 Battery Replacement: adım 3, 1 resimden 1.
    • Take out each of the batteries
  4. Nikon Coolpix L340 Battery Replacement: adım 4, 1 resimden 1.
    • When all of the batteries have been removed you should see four places for four new batteries to be inserted
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Nikki Butts
179 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-3, Bhusal Spring 2016 UMass Dartmouth, Team 3-3, Bhusal Spring 2016 üyesi
UMASSD-BHUSAL-S16S3G3
4 Üyeler
8 adet Kılavuz yazıldı
4Kılavuz Yorumları
Hi, I just replaced my Nikon Coolpix L340's batteries with new AAs and have followed all steps correctly but my camera is still saying 'battery exhausted' when I try turning it back on. Any ideas why it's not working?
Thank you!
Mia - Yanıt
The negative terminal must be raised like the Duracell Ultra. The Energizer MAX and other AAs have a FLAT negative terminal. The manual warns against them.
thestevelink -
No lever, only recessed button
ccpotts47 - Yanıt
thestevelink - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 19
Son 30 gün: 90
Her zaman: 10,685
