Ana içeriğe geç
Nikon Coolpix L340 Battery Replacement
  1. Nikon Coolpix L340 Battery Replacement, Battery: adım 1, 2 resimden 1. Nikon Coolpix L340 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the camera so that the flash is facing downward- you are now looking at the bottom of the camera
    • If the camera lens its pointing towards you, there should be a small lever on the right hand side
    • Take this lever and push it away from your body, while simultaneously pulling upwards
  2. Nikon Coolpix L340 Battery Replacement: adım 2, 2 resimden 1. Nikon Coolpix L340 Battery Replacement: adım 2, 2 resimden 2.
    • Once you have pulled up, four batteries will appear underneith
    • Note how there are two batteries facing upwards (circled in red)
    • and two batteries facing downwards (circled in orange)
    • When the new batteries are placed back in the camera, they should be put back in this same orientation
  3. Nikon Coolpix L340 Battery Replacement: adım 3, 1 resimden 1.
    • Take out each of the batteries
  4. Nikon Coolpix L340 Battery Replacement: adım 4, 1 resimden 1.
    • When all of the batteries have been removed you should see four places for four new batteries to be inserted
    Thank you so much! It was really helpful. You have written it in layman language. I understood everything. Thanks a lot!
    Minu Krishna - Yanıt
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Nikki Butts
179 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-3, Bhusal Spring 2016 UMass Dartmouth, Team 3-3, Bhusal Spring 2016 üyesi
UMASSD-BHUSAL-S16S3G3
4 Üyeler
8 adet Kılavuz yazıldı
4Kılavuz Yorumları
Hi, I just replaced my Nikon Coolpix L340's batteries with new AAs and have followed all steps correctly but my camera is still saying 'battery exhausted' when I try turning it back on. Any ideas why it's not working?
Thank you!
Mia - Yanıt
The negative terminal must be raised like the Duracell Ultra. The Energizer MAX and other AAs have a FLAT negative terminal. The manual warns against them.
thestevelink -
No lever, only recessed button
ccpotts47 - Yanıt
thestevelink - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 19
Son 30 gün: 94
Her zaman: 10,685
