Nikon Coolpix L340 Buttons Replacement
Giriş
1. adıma gitThis guide is meant to help the user replace the buttons on the back of the camera after they remove the back panel. This could be to fix a jammed button or simply replace the part as you wish. The only required tool for this process would be a 5mm Phillips Head number #000 screwdriver.
Neye ihtiyacın var
Aletler
Remove the 5 mm Phillips #000 screw located on the upper left side of the camera
Remove the 5 mm Phillips #000 screw located on the lower left side of the camera
