Ana içeriğe geç
Nikon Coolpix L610 Battery Door Repair
Howard
Howard ve başka bir katkıda bulunan
En son September 3, 2024 tarihinde güncellendi
Tahmin yok
Orta
Topluluk-Katkılı Kılavuz
1 or both small plastic tab breaks on the battery door and chassis preventing battery door from closing. Problem is battery bay spring tension is too high. Need to adjust. If adjusted prior to door breaking, door probably would not have broken.
Made aluminum piece to keep door closed.
Disassemble using Plastic Cover Replacement Guide and Power/Shutter Button Assembly Replacement Guide to access battery spring tensioner.
Small needle nose plier and adjust according to diagram to reduce battery spring tension.
  1. Nikon Coolpix L610 Battery Door Repair, Nikon Coolpix L610 Battery Door Repair: adım 1, 1 resimden 1.
    • Create aluminum bar with bolt to keep broken battery door closed using tripod mount
  2. Nikon Coolpix L610 Battery Door Repair: adım 2, 1 resimden 1.
    • Looks like this assembled
  3. Nikon Coolpix L610 Battery Door Repair: adım 3, 1 resimden 1.
  4. Nikon Coolpix L610 Battery Door Repair: adım 4, 1 resimden 1.
    • Use small needle nose plier to adjust battery spring tension according to diagram. If original spring tension was reduced, battery door likely wouldn't have broken.
Sonuç
Howard
491 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 38
Her zaman: 161
