Nikon Coolpix L610 Camera Lens Replacement
Giriş
1. adıma gitThis guide is to show a user how to change a camera lens. One will need to take the camera completely apart. It is a pretty hard task but if one follow the guides it can be simple.
Neye ihtiyacın var
Remove the four (3.20 mm) Phillips #00 screws at the bottom of the device.
Carefully unscrew and remove the top and bottom (2.25 mm) screws from the control panel.
Carefully unscrew and remove the middle (3.20 mm) screws from the control panel.
Using a prying tool, carefully lift up the LCD screen but do NOT pull it off.
While the LCD screen is loose and unattached, there is a latch that is holding the ribbon in place. Slide the latch down and pull the ribbon out.
Remove the 6 (3.70 mm) screws on the metal cover. Two of those screws are covered by black plastic covers.
After removing the screws the panel should come off and will look like the final image.
There are two lens covers that will fall out after removing the back lens plate.
Remove the 6 (4.35 mm) screws surrounding the lens.
There are 2 more (3.70 mm) screws covered by a small black square located. Remove the black squares and proceed to unscrewing these final screws.
Remove the lens. It should just be free to pull it out.
2 farklı kişi bu kılavuzu tamamladı.
