Ana içeriğe geç
Nikon Coolpix P100  Motherboard Access
Rikki Brown
Rikki Brown ve 5 diğer katkıda bulunanlar
En son July 6, 2020 tarihinde güncellendi
15 dakika
Orta
This guide provides a step by step process on how to access the motherboard on the Nikon Coolpix P100 digital camera.
The motherboard allows all parts of your camera to receive power and communicate with one another. Common symptoms of a faulty motherboard include the screen not receiving any information to display or a quickly draining battery. Before disassembling your Nikon Coolpix P100, be sure to remove any dust or debris from the camera. Keeping your motherboard clean will lessen the probability of any motherboard damage.
Before beginning, be sure to power off your camera and disconnect it from any external power source.
Neye ihtiyacın var
Aletler
  1. Nikon Coolpix P100  Motherboard Access, Nikon Coolpix P100  Motherboard Access: adım 1, 1 resimden 1.
    • Turn the front of the camera toward you.
  2. Nikon Coolpix P100  Motherboard Access: adım 2, 3 resimden 1. Nikon Coolpix P100  Motherboard Access: adım 2, 3 resimden 2. Nikon Coolpix P100  Motherboard Access: adım 2, 3 resimden 3.
    • On the left side of the camera, use a Phillips #00 Precision Screwdriver to remove the two marked screws.
  3. Nikon Coolpix P100  Motherboard Access: adım 3, 1 resimden 1.
    • On the right side of the camera, remove the first visible screw above the HDMI and A/V OUT cover.
  4. Nikon Coolpix P100  Motherboard Access: adım 4, 1 resimden 1.
    • Lift the HDMI and A/V OUT cover to access the hidden screw between the two ports.
    • Remove the screw
  5. Nikon Coolpix P100  Motherboard Access: adım 5, 1 resimden 1.
    • Flip the camera upside down and remove the seven marked screws.
  6. Nikon Coolpix P100  Motherboard Access: adım 6, 2 resimden 1. Nikon Coolpix P100  Motherboard Access: adım 6, 2 resimden 2.
    • Turn the back of the camera toward you.
    • Lift the display panel and remove the two marked screws
  7. Nikon Coolpix P100  Motherboard Access: adım 7, 3 resimden 1. Nikon Coolpix P100  Motherboard Access: adım 7, 3 resimden 2. Nikon Coolpix P100  Motherboard Access: adım 7, 3 resimden 3.
    • Use a plastic iFixit opening tool to gently loosen the top and sides of the camera.
  8. Nikon Coolpix P100  Motherboard Access: adım 8, 1 resimden 1.
    • Before fully opening the camera, identify the two marked ribbon cables
    • Properly detach the ribbons before proceeding
  9. Nikon Coolpix P100  Motherboard Access: adım 9, 1 resimden 1.
    • Carefully open the camera.
    • Now you have partial access to the camera's motherboard.
  10. Nikon Coolpix P100  Motherboard Access: adım 10, 1 resimden 1.
    • Remove the five indicated screws that are attached to the metal plate.
  11. Nikon Coolpix P100  Motherboard Access: adım 11, 1 resimden 1.
    • Remove the hidden top screw that is attached to the metal plate.
  12. Nikon Coolpix P100  Motherboard Access: adım 12, 1 resimden 1.
    • Use a plastic iFixit opening tool to carefully loosen the metal plate.
    • Remove the metal plate to access the camera's motherboard.
  13. Nikon Coolpix P100  Motherboard Access: adım 13, 1 resimden 1.
    • Now you have access to the camera's motherboard
Sonuç
Rikki Brown
267 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Tanski Winter 2015 USF Tampa, Team 1-1, Tanski Winter 2015 üyesi
USFT-TANSKI-W15S1G1
3 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
y como cambia el lente si se atasca
djalfonsodaza - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 34
Her zaman: 2,708
