Ana içeriğe geç
Nikon Coolpix P510 Lens Casing Replacement
Neye ihtiyacın var
    1. Nikon Coolpix P510 Lens Casing Replacement, Lens Assembly: adım 1, 2 resimden 1. Nikon Coolpix P510 Lens Casing Replacement, Lens Assembly: adım 1, 2 resimden 2.
      • Flip the camera upside down and remove six 3mm PH00 Philips screws with a Philips screwdriver.
      • On the thumb grip, remove the one 4mm PH00 Philips screw.
      FixBot'a Sor
      Yorum Ekle
    2. Nikon Coolpix P510 Lens Casing Replacement: adım 2, 1 resimden 1.
      • With the camera upside down, remove the three 3mm PH00 Philips screws on the left side.
      • One of the screws are under the HDMI and A/V Out cover.
      FixBot'a Sor
      Yorum Ekle
    3. Nikon Coolpix P510 Lens Casing Replacement: adım 3, 1 resimden 1.
      • On the opposite side of the camera, remove the two 3mm PH00 Philips screws.
      FixBot'a Sor
      Yorum Ekle
    4. Nikon Coolpix P510 Lens Casing Replacement: adım 4, 1 resimden 1.
      • open the display and remove the two Ph 00 screws near the hinge
      FixBot'a Sor
      Yorum Ekle
    5. Nikon Coolpix P510 Lens Casing Replacement: adım 5, 3 resimden 1. Nikon Coolpix P510 Lens Casing Replacement: adım 5, 3 resimden 2. Nikon Coolpix P510 Lens Casing Replacement: adım 5, 3 resimden 3.
      • Open the flash and use a plastic opening tool to pop the tab under it as shown.
      • Now pull the casing apart.
      • The tripod attachment may fall out on its own, or you will need to pull it out.
      FixBot'a Sor
      Yorum Ekle
    6. Nikon Coolpix P510 Lens Casing Replacement: adım 6, 2 resimden 1. Nikon Coolpix P510 Lens Casing Replacement: adım 6, 2 resimden 2.
      • Unplug the two ribbon cables to completely detach the back, by securely opening the latch
      FixBot'a Sor
      Yorum Ekle
    7. Nikon Coolpix P510 Lens Casing Replacement: adım 7, 3 resimden 1. Nikon Coolpix P510 Lens Casing Replacement: adım 7, 3 resimden 2. Nikon Coolpix P510 Lens Casing Replacement: adım 7, 3 resimden 3.
      • With the back separated, you need to remove six 3mm PH000 Philips screws with a Philips screwdriver.
      • Remove one 5mm PH00 Philips screw
      • To remove the top right corner screw, you may need to lift the corner of the case to gain access to it.
      • With all the screws out, the metal plate should simply lift off.
      FixBot'a Sor
      Yorum Ekle
    8. Nikon Coolpix P510 Lens Casing Replacement: adım 8, 2 resimden 1. Nikon Coolpix P510 Lens Casing Replacement: adım 8, 2 resimden 2.
      • With the metal plate off, unplug this ribbon cable from the motherboard.
      • To remove the flat-topped connector, you simply lift it up to unplug it.
      FixBot'a Sor
      Yorum Ekle
    9. Nikon Coolpix P510 Lens Casing Replacement: adım 9, 3 resimden 1. Nikon Coolpix P510 Lens Casing Replacement: adım 9, 3 resimden 2. Nikon Coolpix P510 Lens Casing Replacement: adım 9, 3 resimden 3.
      • To get the lens assembly out, you need to remove four 6mm PH00 Philips screws
      FixBot'a Sor
      Yorum Ekle
    10. Nikon Coolpix P510 Lens Casing Replacement: adım 10, 2 resimden 1. Nikon Coolpix P510 Lens Casing Replacement: adım 10, 2 resimden 2.
      • With the support screws out, you can simply slide the assembly out of the casing.
      FixBot'a Sor
      Yorum Ekle
    11. Nikon Coolpix P510 Lens Casing Replacement: adım 11, 3 resimden 1. Nikon Coolpix P510 Lens Casing Replacement: adım 11, 3 resimden 2. Nikon Coolpix P510 Lens Casing Replacement: adım 11, 3 resimden 3.
      • If you are moving on to take the lens casing off, you do not need to do this step.
      • With the assembly out we need to take of this last piece by removing the three 3mm PH000 Philips screws.
      FixBot'a Sor
      Yorum Ekle
    1. Nikon Coolpix P510 Lens Casing Replacement, Lens Casing: adım 12, 2 resimden 1. Nikon Coolpix P510 Lens Casing Replacement, Lens Casing: adım 12, 2 resimden 2.
      • Remove the five PH00 screws surrounding the lens.
      FixBot'a Sor
      Yorum Ekle
    2. Nikon Coolpix P510 Lens Casing Replacement: adım 13, 1 resimden 1.
      • Separate the lens casing from the front.
      • The switch on the side simply slides off of the front casing.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device or to attach a new lense, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
3 farklı kişi bu kılavuzu tamamladı.
Brian Hulsey
1.554 İtibar
6 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 2-2, Panko Spring 2015 Colorado Springs, Team 2-2, Panko Spring 2015 üyesi
UCCS-PANKO-S15S2G2
3 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 32
Her zaman: 3,848
