Giriş
Replace the eyepiece (plastic rectangular piece around the viewfinder) if it is loose, broken, or lost.
Aletler
Parçalar
Hiçbir parçaya gerek yok.
Use your finger to push the notch of the compartment door to the center of the camera body.
Release the compartment door, and it will swing open.
Remove the existing battery with your fingers.
Remove both 4.5 mm screws holding the bottom into place.
Remove both 4.5 mm screws holding the side into place.
Remove the 4.5 mm screw underneath the A/V flap.
Remove the 4.0 mm screw on the left-side wrist strap loop.
Bir başkası bu kılavuzu tamamladı.
