Ana içeriğe geç
Nikon Coolpix P90 Flash Bulb Replacement
Neye ihtiyacın var
    1. Nikon Coolpix P90 Flash Bulb Replacement, Camera Base: adım 1, 3 resimden 1. Nikon Coolpix P90 Flash Bulb Replacement, Camera Base: adım 1, 3 resimden 2. Nikon Coolpix P90 Flash Bulb Replacement, Camera Base: adım 1, 3 resimden 3.
      • Use your finger to push the latch of the compartment door to the center of the camera body, per image 1.
      • Push the door open, and remove the existing battery with your fingers, per images 2-3.
      FixBot'a Sor
      Yorum Ekle
    1. Nikon Coolpix P90 Flash Bulb Replacement, Flash Bulb: adım 2, 2 resimden 1. Nikon Coolpix P90 Flash Bulb Replacement, Flash Bulb: adım 2, 2 resimden 2.
      • Press the button on the side of the body to open the flash compartment.
      FixBot'a Sor
      Yorum Ekle
    2. Nikon Coolpix P90 Flash Bulb Replacement: adım 3, 1 resimden 1.
      • Using a Phillips #000 Precision Screwdriver, remove the two 3.0 mm screws from inside the compartment.
      FixBot'a Sor
      Yorum Ekle
    3. Nikon Coolpix P90 Flash Bulb Replacement: adım 4, 1 resimden 1.
      • Place the plastic opening tool along the crack on the side of the flash compartment cover and pry open and detach the cover.
      FixBot'a Sor
      Yorum Ekle
    4. Nikon Coolpix P90 Flash Bulb Replacement: adım 5, 2 resimden 1. Nikon Coolpix P90 Flash Bulb Replacement: adım 5, 2 resimden 2.
      • Using a Phillips #000 Precision Screwdriver, remove the 4.0 mm screw from the plastic cover.
      • Detach the plastic cover.
      FixBot'a Sor
      Yorum Ekle
    5. Nikon Coolpix P90 Flash Bulb Replacement: adım 6, 2 resimden 1. Nikon Coolpix P90 Flash Bulb Replacement: adım 6, 2 resimden 2.
      • Carefully remove the flash bulb holder with your fingers.
      FixBot'a Sor
      Yorum Ekle
    6. Nikon Coolpix P90 Flash Bulb Replacement: adım 7, 1 resimden 1.
      • Using the plastic opening tool, pry the metal bulb frame out of the socket.
      FixBot'a Sor
      Yorum Ekle
    7. Nikon Coolpix P90 Flash Bulb Replacement: adım 8, 1 resimden 1.
      • Remove the plastic stoppers on either side of the metal flash bulb tray.
      FixBot'a Sor
      Yorum Ekle
    8. Nikon Coolpix P90 Flash Bulb Replacement: adım 9, 1 resimden 1.
      • Using a soldering iron, desolder each of the wires connected to the light bulb.
      • Be careful! The soldering iron is hot. Do not burn yourself or the device. It should not be applied to the device too long to avoid damaging any of the device components.
      • For a comprehensive guide on desoldering, visit iFixit's Soldering and Desoldering Guide.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Elizabeth Kamine
664 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-14, Maness Winter 2015 Cal Poly, Team 20-14, Maness Winter 2015 üyesi
CPSU-MANESS-W15S20G14
4 Üyeler
19 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 45
Her zaman: 1,292
