Ana içeriğe geç
Nikon Coolpix S230 Lens Assembly Replacement
Neye ihtiyacın var
  1. Nikon Coolpix S230 Lens Assembly Replacement, LCD Screen: adım 1, 3 resimden 1. Nikon Coolpix S230 Lens Assembly Replacement, LCD Screen: adım 1, 3 resimden 2. Nikon Coolpix S230 Lens Assembly Replacement, LCD Screen: adım 1, 3 resimden 3.
    • Ensure the camera is turned off and the battery is removed.
    • Using a Phillips #000 screwdriver, remove the four 2-mm screws from the side of the camera.
    • Remove the two 3-mm screws from the other side of the camera.
    • Finally, remove the three 4-mm screws from the bottom of the camera.
  2. Nikon Coolpix S230 Lens Assembly Replacement: adım 2, 3 resimden 1. Nikon Coolpix S230 Lens Assembly Replacement: adım 2, 3 resimden 2. Nikon Coolpix S230 Lens Assembly Replacement: adım 2, 3 resimden 3.
    • Insert the plastic opening tool into the seam where the front and back parts of the case meet on the bottom of the camera, and slide it along the bottom. Continue along the next side to separate the back part of the case.
    • If necessary, continue along the third and fourth sides until the case separates easily.
    • Lift the back off of the case.
  3. Nikon Coolpix S230 Lens Assembly Replacement: adım 3, 2 resimden 1. Nikon Coolpix S230 Lens Assembly Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Carefully lift the LCD screen to reveal two orange ribbons connecting the screen to the camera.
    • Use tweezers to carefully lift the blue retaining flap holding down the orange ribbon cable. (Flap can be seen open in the second photo)
    • Slowly wiggle the ribbon cable back and forth while pulling away from the zero insertion force (ZIF) connector to disconnect the cable.
  4. Nikon Coolpix S230 Lens Assembly Replacement: adım 4, 2 resimden 1. Nikon Coolpix S230 Lens Assembly Replacement: adım 4, 2 resimden 2.
    • Using tweezers, lift the black retaining flap holding down the larger orange ribbon cable.
    • Carefully remove the ribbon cable from the ZIF connector as before.
  5. Nikon Coolpix S230 Lens Assembly Replacement: adım 5, 1 resimden 1.
    • Lift the LCD screen away from the camera.
  6. Nikon Coolpix S230 Lens Assembly Replacement, Button Circuit Board: adım 6, 1 resimden 1.
    • Lift the button circuit board by gently popping it out of its connector.
  7. Nikon Coolpix S230 Lens Assembly Replacement, Lens Assembly: adım 7, 1 resimden 1.
    • Using a Phillips #000 screwdriver, remove the four 4-mm screws from the metal place.
  8. Nikon Coolpix S230 Lens Assembly Replacement: adım 8, 2 resimden 1. Nikon Coolpix S230 Lens Assembly Replacement: adım 8, 2 resimden 2.
    • Lift the plate from the camera to reveal the motherboard.
    • Once the plate is removed, the metal attachment for the camera strap on the side of the camera will no longer be secured to the device, and should be set aside.
  9. Nikon Coolpix S230 Lens Assembly Replacement: adım 9, 2 resimden 1. Nikon Coolpix S230 Lens Assembly Replacement: adım 9, 2 resimden 2.
    • Use tweezers to lift the black retaining flap for the larger ribbon cable connecting the motherboard to the lens.
    • Continue using the tweezers to gently pull the ribbon cable out of the ZIF connector.
  10. Nikon Coolpix S230 Lens Assembly Replacement: adım 10, 2 resimden 1. Nikon Coolpix S230 Lens Assembly Replacement: adım 10, 2 resimden 2.
    • Use tweezers to lift the beige retaining flap for the smaller, orange ribbon cable that attaches the motherboard to the lens.
    • Use tweezers to gently pull the orange ribbon cable from the ZIF connector.
  11. Nikon Coolpix S230 Lens Assembly Replacement: adım 11, 1 resimden 1.
    • Remove the solder using a soldering iron by following the instructions in this guide.
  12. Nikon Coolpix S230 Lens Assembly Replacement: adım 12, 1 resimden 1.
    • Lift the motherboard from the camera to reveal the lens assembly.
    • The motherboard is still attached to the camera by the wires connected to the speaker and mic.
  13. Nikon Coolpix S230 Lens Assembly Replacement: adım 13, 2 resimden 1. Nikon Coolpix S230 Lens Assembly Replacement: adım 13, 2 resimden 2.
    • Using a Phillips #000 screwdriver, remove the two visible 5-mm screws that attach the lens to the camera.
    • Remove the third 5-mm screw by carefully lifting the large ribbon cable that is attached to the lens.
  14. Nikon Coolpix S230 Lens Assembly Replacement: adım 14, 1 resimden 1.
    • Lift the lens assembly from the camera.
Sonuç
Chris Helms
1 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team 3-1, Whitney Spring 2017 Baylor, Team 3-1, Whitney Spring 2017 üyesi
BU-WHITNEY-S17S3G1
4 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 24
Her zaman: 871
