Ana içeriğe geç
Nikon Coolpix S3100 Camera Lens Replacement
Neye ihtiyacın var
  1. Nikon Coolpix S3100 Camera Lens Replacement, Nikon Coolpix S3100 disassembly: adım 1, 3 resimden 1. Nikon Coolpix S3100 Camera Lens Replacement, Nikon Coolpix S3100 disassembly: adım 1, 3 resimden 2. Nikon Coolpix S3100 Camera Lens Replacement, Nikon Coolpix S3100 disassembly: adım 1, 3 resimden 3.
    • Remove 8-2.46 mm screws from both sides and bottom of camera using a #000 Phillips screwdriver.
    • Remove 2 screws from left side. (picture 1)
    • Remove 4 screws from bottom. (picture 2)
    • Remove 2 screws from right side. (picture 3)
  2. Nikon Coolpix S3100 Camera Lens Replacement: adım 2, 2 resimden 1. Nikon Coolpix S3100 Camera Lens Replacement: adım 2, 2 resimden 2.
    • Remove black cover pulling up with left thumb. Hold silver cover with right thumb.
    • Remove silver cover lifting up with left thumb. Hold the camera with right thumb.
    • Once internal circuit board is exposed, the red and blue wire terminals at top center can provide a nasty shock from the charged flash capacitor (silver can to left of terminals). BE CAREFUL!
  3. Nikon Coolpix S3100 Camera Lens Replacement: adım 3, 2 resimden 1. Nikon Coolpix S3100 Camera Lens Replacement: adım 3, 2 resimden 2.
    • Remove 2-2.10mm screws in the front of the camera using a #000 Phillips screwdriver.
    • Remove the two screws.
    • Gently pull up to detach the frame. (picture 2)
  4. Nikon Coolpix S3100 Camera Lens Replacement, LCD Screen: adım 4, 1 resimden 1.
    • Remove 2-2.10mm screws using a #000 Phillips screwdriver.
  5. Nikon Coolpix S3100 Camera Lens Replacement: adım 5, 1 resimden 1.
    • Gently pull the orange board to the right.
  6. Nikon Coolpix S3100 Camera Lens Replacement: adım 6, 1 resimden 1.
    • Lift screen up holding both corners.
  7. Nikon Coolpix S3100 Camera Lens Replacement: adım 7, 1 resimden 1.
    • Gently pull to the left to release from ZIF connector.
  8. Nikon Coolpix S3100 Camera Lens Replacement, Lens: adım 8, 1 resimden 1.
    • Remove 4-2.10mm screws using a #000 Phillips screwdriver.
  9. Nikon Coolpix S3100 Camera Lens Replacement: adım 9, 1 resimden 1.
    • Gently pull the shutter up.
  10. Nikon Coolpix S3100 Camera Lens Replacement: adım 10, 1 resimden 1.
    • Remove 3-2.12mm screws using #000 Phillips screwdriver.
  11. Nikon Coolpix S3100 Camera Lens Replacement: adım 11, 1 resimden 1.
    • Use a nylon or metal spudger to release the lens.
  12. Nikon Coolpix S3100 Camera Lens Replacement: adım 12, 1 resimden 1.
    • Repeat step 4 to the opposite side of the lens.
  13. Nikon Coolpix S3100 Camera Lens Replacement: adım 13, 1 resimden 1.
    • The lens is now separated.
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Jorge
1.170 İtibar
7 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 2-4, Panko Spring 2015 Colorado Springs, Team 2-4, Panko Spring 2015 üyesi
UCCS-PANKO-S15S2G4
2 Üyeler
13 adet Kılavuz yazıldı
6Kılavuz Yorumları
My lens shutter does not open correctly. After turning the camera on, the shutter only half opens with a juddering motion. Any ideas?
Anita
William Dawson - Yanıt
Nikon coolpix s3100 lens mocking place help my
Nanji Buchiya - Yanıt
My lens shutter does not open correctly after turning on and after close with juddering repeatly how can be repaired
Bimolthou Thuodam - Yanıt
I have same issue it shutter half opens and doesnt open correctly
shailendra - Yanıt
my LCD screen is stuck on white after after i did this :(
andrew welles - Yanıt
After I put the lens in place, the camera works and the front lens retracts, but the image is blurry and it immediately says that the lens has an error and the camera turns off. what should I do?
last mountaineer - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 80
Her zaman: 4,747
