Giriş
To replace the LCD screen of your camera, you'll need to go through a few steps of disassembly including the steps from the Back Cover replacement guide.
Neye ihtiyacın var
Remove all four T5 Torx screws from the exterior of the camera.
Remove all three T5 Torx screws located at the bottom of the camera next to the battery compartment.
Using a plastic opening tool, pry the LCD screen out of its slot inside of the camera.
Bir başkası bu kılavuzu tamamladı.
Der große Kreis an der Unterseite ist keine Schraube. Hier gehört einfach das Stativ festgeschraubt;-)
Lolos Allerlei - Yanıt
