Ana içeriğe geç
Nikon Coolpix S51c LCD Screen Replacement
Neye ihtiyacın var
    1. Nikon Coolpix S51c LCD Screen Replacement, Back Cover: adım 1, 2 resimden 1. Nikon Coolpix S51c LCD Screen Replacement, Back Cover: adım 1, 2 resimden 2.
      • First, use a Phillips #00 screwdriver to remove all five screws that are located at the bottom of the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Nikon Coolpix S51c LCD Screen Replacement: adım 2, 1 resimden 1.
      • Next, slide the battery door open in the direction of the arrow to reveal a hidden screw on the opposite side of the orange lever.
      • Remove this screw using the Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Nikon Coolpix S51c LCD Screen Replacement: adım 3, 1 resimden 1.
      • Rotate the camera to find the side panel with the lanyard attachment.
      • Detach the side panel by the lifting bottom corner slightly with the spudger.
      FixBot'a Sor
      Yorum Ekle
    4. Nikon Coolpix S51c LCD Screen Replacement: adım 4, 1 resimden 1.
      • Lift the back cover.
      • Be careful not to rip the orange cables between the camera and the back cover.
      FixBot'a Sor
      Yorum Ekle
    5. Nikon Coolpix S51c LCD Screen Replacement: adım 5, 1 resimden 1.
      • With the back cover lifted, lift the black flap that connects the ribbon to the motherboard with the spudger.
      • Carefully remove the back cover.
      FixBot'a Sor
      Yorum Ekle
    1. Nikon Coolpix S51c LCD Screen Replacement, LCD Screen: adım 6, 1 resimden 1.
      • On back of LCD screen, locate the three screws underneath the ribbon.
      • Remove each screw using your screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Nikon Coolpix S51c LCD Screen Replacement: adım 7, 2 resimden 1. Nikon Coolpix S51c LCD Screen Replacement: adım 7, 2 resimden 2.
      • Take out the rectangular component on the side where the screws were.
      • Carefully, pry apart the screen from the back casing using the spudger.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Bir başkası bu kılavuzu tamamladı.
Ryan
167 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-24, Garner Spring 2011 Cal Poly, Team 18-24, Garner Spring 2011 üyesi
CPSU-GARNER-S11S18G24
4 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 44
Her zaman: 3,011
