Ana içeriğe geç
Nikon D3100 Motherboard Replacement
Neye ihtiyacın var
    1. Nikon D3100 Motherboard Replacement, LCD Screen: adım 1, 1 resimden 1.
      • Use a Phillips #00 screwdriver for all of the screws.
      • Remove two of the 4mm screws indicated by the circles on the bottom side of the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Nikon D3100 Motherboard Replacement: adım 2, 2 resimden 1. Nikon D3100 Motherboard Replacement: adım 2, 2 resimden 2.
      • Remove four of the 3mm screws around the eye piece located on the top of the back panel, including the screw hidden behind the auto focus label.
      • Remove the 3mm screw behind the rubber grip on the top right of the back panel.
      FixBot'a Sor
      Yorum Ekle
    3. Nikon D3100 Motherboard Replacement: adım 3, 1 resimden 1.
      • Peel back the rubber grip on the right side of the camera using a spudger.
      • You may need a heating pad to melt the glue holding the rubber grip to the camera. If using the heating pad, use caution and handle carefully.
      • Remove two of the 5mm screws under the rubber grip.
      FixBot'a Sor
      Yorum Ekle
    4. Nikon D3100 Motherboard Replacement: adım 4, 1 resimden 1.
      • Remove two of the 4mm screws on the left side of the camera.
      FixBot'a Sor
      Yorum Ekle
    5. Nikon D3100 Motherboard Replacement: adım 5, 2 resimden 1. Nikon D3100 Motherboard Replacement: adım 5, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Starting from the top, gently lift the back panel of the camera off. Slowly separate the back panel from the main body of the camera.
      • Be careful not to pull the panel out too fast or the ribbon may be damaged.
      • Carefully remove the ribbon using a spudger to lift up the connector and then use tweezers to pull out the ribbon.
      • Separate the back panel from the main body of the camera.
      FixBot'a Sor
      Yorum Ekle
    6. Nikon D3100 Motherboard Replacement: adım 6, 1 resimden 1.
      • Be careful when separating the metal plate from the back panel because the speaker wire is connected to the metal plate. It can easily be torn if caution is not taken.
      • Remove nine of the 3mm screws connecting the metal plate to the plastic panel.
      FixBot'a Sor
      Yorum Ekle
    7. Nikon D3100 Motherboard Replacement: adım 7, 1 resimden 1.
      • Remove the tape covering the ribbons. Be careful not to break the tape.
      FixBot'a Sor
      Yorum Ekle
    8. Nikon D3100 Motherboard Replacement: adım 8, 1 resimden 1.
      • Remove the two ribbons connecting the LCD screen to the metal plate using the same method from Step 5.
      FixBot'a Sor
      Yorum Ekle
    9. Nikon D3100 Motherboard Replacement: adım 9, 1 resimden 1.
      • Remove the old LCD screen from metal plate.
      FixBot'a Sor
      Yorum Ekle
    1. Nikon D3100 Motherboard Replacement, Motherboard: adım 10, 2 resimden 1. Nikon D3100 Motherboard Replacement, Motherboard: adım 10, 2 resimden 2.
      • Use tweezers to gently lift the yellow tape from the back of the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Nikon D3100 Motherboard Replacement: adım 11, 1 resimden 1.
      • Use a plastic spudger to remove the 6 ribbons.
      • Be careful not to tear the ribbons.
      FixBot'a Sor
      Yorum Ekle
    3. Nikon D3100 Motherboard Replacement: adım 12, 2 resimden 1. Nikon D3100 Motherboard Replacement: adım 12, 2 resimden 2.
      • Remove the plug located on the top-right side of the camera.
      • Remove the plug located on the top-left side of the camera.
      FixBot'a Sor
      Yorum Ekle
    4. Nikon D3100 Motherboard Replacement: adım 13, 1 resimden 1.
      • Use a Philips #00 Screwdriver to remove the five 3 mm screws marked in the image.
      FixBot'a Sor
      Yorum Ekle
    5. Nikon D3100 Motherboard Replacement: adım 14, 2 resimden 1. Nikon D3100 Motherboard Replacement: adım 14, 2 resimden 2.
      • Gently pull out the side wall of the camera so that the motherboard comes out easier.
      • Do not pull too hard or you will risk breaking the plastic.
      FixBot'a Sor
      Yorum Ekle
    6. Nikon D3100 Motherboard Replacement: adım 15, 1 resimden 1.
      • Be careful while lifting the motherboard because there is one more ribbon attached.
      • Gently lift the motherboard to separate it from the back of the camera.
      • Use a plastic spudger to detach the ribbon.
      FixBot'a Sor
      Yorum Ekle
    7. Nikon D3100 Motherboard Replacement: adım 16, 1 resimden 1.
      • Replace the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Jet Mejia
686 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 14-1, Eyestone Fall 2016 USF Tampa, Team 14-1, Eyestone Fall 2016 üyesi
USFT-EYESTONE-F16S14G1
3 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 18
Son 30 gün: 100
Her zaman: 6,698
