Ana içeriğe geç
Nikon D5000 Battery Door Replacement
  1. Nikon D5000 Battery Door Replacement, Battery Door: adım 1, 2 resimden 1. Nikon D5000 Battery Door Replacement, Battery Door: adım 1, 2 resimden 2.
    • On the bottom of the camera, pull the release tab towards the center of the camera, then pull up.
  2. Nikon D5000 Battery Door Replacement: adım 2, 2 resimden 1. Nikon D5000 Battery Door Replacement: adım 2, 2 resimden 2.
    • Grip and hold the front end of the battery door at a 45-degree angle from the case.
    • Pop the battery door out by pulling the front tab up.
    • When reassembling, seat the rear tab in its slot before pushing the front tab back in.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jacob Rardin
1.448 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-28, Maness Spring 2014 Cal Poly, Team 13-28, Maness Spring 2014 üyesi
CPSU-MANESS-S14S13G28
4 Üyeler
7 adet Kılavuz yazıldı
1Rehber Yorum
My problem is the door on my Nikon D850 broke, leaving the small part with the two prongs in place, and I don’t know how to get them out to install a replacement door. Would appreciate suggestions tootswaller22@gmail.com
Harry Langdon - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 19
Son 30 gün: 73
Her zaman: 5,647
