Ana içeriğe geç
Nikon D5200 Motherboard Or Camera Back Replacement
Alexander Corn
Alexander Corn ve 5 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
30 dakika
Orta
This guide takes you through a step-by-step process to replace your camera's motherboard. The first seven steps can also be used to replace the camera back, which is a handy way to replace the LCD without having to de-solder any wires. If you are going the whole way and replacing the motherboard, you will need to use a soldering iron during this process, in which case be sure to use caution when doing so!
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Nikon D5200 Motherboard Or Camera Back Replacement, Remove Battery, SD Card, Bottom Screws.: adım 1, 1 resimden 1.
    • Remove the three 3.5-mm screws from the underside of the camera that are circled.
    • Remove the battery, and any SD card that is in the camera.
  2. Nikon D5200 Motherboard Or Camera Back Replacement: adım 2, 2 resimden 1. Nikon D5200 Motherboard Or Camera Back Replacement: adım 2, 2 resimden 2.
    • Remove the 7-mm screws from either side of the camera.
  3. Nikon D5200 Motherboard Or Camera Back Replacement: adım 3, 2 resimden 1. Nikon D5200 Motherboard Or Camera Back Replacement: adım 3, 2 resimden 2.
    • Gently pry back the rubber pad on the back of the camera with a metal spudger or other tool, or your fingernail, to reveal a hidden screw.
    • Remove the 4-mm screw.
  4. Nikon D5200 Motherboard Or Camera Back Replacement: adım 4, 3 resimden 1. Nikon D5200 Motherboard Or Camera Back Replacement: adım 4, 3 resimden 2. Nikon D5200 Motherboard Or Camera Back Replacement: adım 4, 3 resimden 3.
    • If a rubber guard is present around the viewfinder, press upward on the guard to remove it.
    • Remove the three 7mm screws around the viewfinder.
  5. Nikon D5200 Motherboard Or Camera Back Replacement: adım 5, 3 resimden 1. Nikon D5200 Motherboard Or Camera Back Replacement: adım 5, 3 resimden 2. Nikon D5200 Motherboard Or Camera Back Replacement: adım 5, 3 resimden 3.
    • Carefully use a metal spudger to remove the cap from the dioptric adjustment dial to reveal a screw. Note that you are only removing the cover -- the insert on the dial that has the "+/-" on it -- not the entire knurled ring.
    • Remove the 12-mm screw.
  6. Nikon D5200 Motherboard Or Camera Back Replacement: adım 6, 3 resimden 1. Nikon D5200 Motherboard Or Camera Back Replacement: adım 6, 3 resimden 2. Nikon D5200 Motherboard Or Camera Back Replacement: adım 6, 3 resimden 3.
    • Once all screws have been removed, carefully pull the casing apart. Take care not to pull any wires apart.
  7. Nikon D5200 Motherboard Or Camera Back Replacement: adım 7, 3 resimden 1. Nikon D5200 Motherboard Or Camera Back Replacement: adım 7, 3 resimden 2. Nikon D5200 Motherboard Or Camera Back Replacement: adım 7, 3 resimden 3.
    • Use a plastic opening tool to unplug the two ribbon cables connecting the two parts of the casing.
    • The orange-brown ribbon cable has a tiny brown plastic latch/door that flips up to release the cable. The silver ribbon is simply pressed into place; the ends are the safest point to gently pry it off to avoid damaging its wires.
    • If you are only replacing the camera back, stop here and reverse the preceding steps to install the new back.
  8. Nikon D5200 Motherboard Or Camera Back Replacement: adım 8, 3 resimden 1. Nikon D5200 Motherboard Or Camera Back Replacement: adım 8, 3 resimden 2. Nikon D5200 Motherboard Or Camera Back Replacement: adım 8, 3 resimden 3.
    • Remove the 3.5-mm screws around the edges of the metal plate covering the motherboard.
    • Pull the metal plate off and away from the motherboard.
  9. Nikon D5200 Motherboard Or Camera Back Replacement: adım 9, 3 resimden 1. Nikon D5200 Motherboard Or Camera Back Replacement: adım 9, 3 resimden 2. Nikon D5200 Motherboard Or Camera Back Replacement: adım 9, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers to remove the small cable in the top-left corner of the motherboard from its socket.
    • Use a plastic opening tool to unplug the remaining ribbon cables.
  10. Nikon D5200 Motherboard Or Camera Back Replacement: adım 10, 3 resimden 1. Nikon D5200 Motherboard Or Camera Back Replacement: adım 10, 3 resimden 2. Nikon D5200 Motherboard Or Camera Back Replacement: adım 10, 3 resimden 3.
    • Remove the motherboard from its seat and lift it up.
    • Unplug the red and blue wires from their socket.
  11. Nikon D5200 Motherboard Or Camera Back Replacement: adım 11, 2 resimden 1. Nikon D5200 Motherboard Or Camera Back Replacement: adım 11, 2 resimden 2.
    • Desolder the small wires in the upper-left corner of the motherboard.
    • Soldering irons become very hot when in use. Take all necessary precautions to avoid injury.
    Una guía para sacar el modos dial.
    William - Yanıt
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
Alexander Corn
1.312 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-1, Eyestone Fall 2015 USF Tampa, Team 3-1, Eyestone Fall 2015 üyesi
USFT-EYESTONE-F15S3G1
4 Üyeler
7 Yorum
How did you remove the cap from dioptric adjustment dial without braking the cap in step5?
cghh dbv - Yanıt
there is a sticker above it you've to remove the sticker not the whol cap, the under the sticker you will see the screw
prince.x96 -
I soaked the back of my camera, which fried the LCD and one of the buttons. Bought a new back on eBay for $60 and used this to replace it in about an hour. This might be the preferred way to replace the LCD for some folks, to avoid having to what appears to be a fairly delicate desolder-resolder to replace only the LCD. As of the time of this comment, the parts cost a little bit more -- like $20 for LCD vs $60 for the full back, but not prohibitively so.
Joseph Morris - Yanıt
Does the motherboard which I ordered from aliexpress work in a camera which i bought in moscow russia??
Mathias - Yanıt
Does the motherboard which i ordered from aliexpress work with a camera nikon d5200 which i bought in moscow russia?
Mathias - Yanıt
Hi nice presentation - does not look too difficult. My camera repair man however tells me that a replacement motherboard is non-functional with the camera unless properly programmed by Nikon software. Is there a way around this? There are several vendors of of D5200 replacement motherboards on eBay - are these normally programmed? Kind Regards, Hans Eric
Hans Eric Anders Widell - Yanıt
Hi im from iran (d5200)
I want a shot from under the memory card slat in board please send to my instagram or tellegram(@amirmohammad_rajabi) @amrjarj@gmail.com
امیر رجبی - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 75
Her zaman: 10,978
