Ana içeriğe geç
Nikon D5200 Screen Replacement
Neye ihtiyacın var
  1. Nikon D5200 Screen Replacement, Screen: adım 1, 3 resimden 1. Nikon D5200 Screen Replacement, Screen: adım 1, 3 resimden 2. Nikon D5200 Screen Replacement, Screen: adım 1, 3 resimden 3.
    • Fully open the LCD panel so that its screws are easily accessible.
    • Remove the two 2.5 mm screws from the outside edge of the screen casing, and the two 3.5 mm screws from the inside edge.
  2. Nikon D5200 Screen Replacement: adım 2, 3 resimden 1. Nikon D5200 Screen Replacement: adım 2, 3 resimden 2. Nikon D5200 Screen Replacement: adım 2, 3 resimden 3.
    • Pry open the plastic casing using the opening tool or by hand.
  3. Nikon D5200 Screen Replacement: adım 3, 3 resimden 1. Nikon D5200 Screen Replacement: adım 3, 3 resimden 2. Nikon D5200 Screen Replacement: adım 3, 3 resimden 3.
    • Use the plastic opening tool to pop up the latch holding the ribbon cable on the right side of the circuit board, and remove it.
    • Use the plastic opening tool to pry the ribbon cable on the left side of the circuit board up and off of its socket.
  4. Nikon D5200 Screen Replacement: adım 4, 2 resimden 1. Nikon D5200 Screen Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using tweezers, unplug the smaller cable.
  5. Nikon D5200 Screen Replacement: adım 5, 2 resimden 1. Nikon D5200 Screen Replacement: adım 5, 2 resimden 2.
    • Desolder the three small wires on the left side of the circuit board.
    • Soldering irons become very hot when in use. Take all necessary precautions to avoid injury.
    If you just need to replace the LCD itself, the soldering isn't needed. The board is attached to the LCD with two small adhesive stripes. So you can remove the board, switch out the LCD and attach the board back again onto the new LCD. Worked like a charm.
    Sascha Brückl - Yanıt
  6. Nikon D5200 Screen Replacement: adım 6, 3 resimden 1. Nikon D5200 Screen Replacement: adım 6, 3 resimden 2. Nikon D5200 Screen Replacement: adım 6, 3 resimden 3.
    • Using a spudger, remove the display from its casing.
    This helped me a great deal determining if it was my actual lcd or connection problem!
    rudy_saram - Yanıt
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
Alexander Corn
1.312 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-1, Eyestone Fall 2015 USF Tampa, Team 3-1, Eyestone Fall 2015 üyesi
USFT-EYESTONE-F15S3G1
4 Üyeler
9Kılavuz Yorumları
Do I need to de-solder if I'm just replacing the window glass?
isaac - Yanıt
To isaac: no. The exterior glass is separate from the LCD.
Joseph Morris - Yanıt
Do you recommend the replacent for LCD sold on Ebay?
g_atki - Yanıt
Where did you find the replacement screen? The one I ordered that says it's for the d5200 is not the same as the one in it or in your pictures.
Heather Miller - Yanıt
How do you disconnect the multi-plug that is shown connected in image 4 and disconnected in image five? Does it unclip or slide out?
Amanda Bruyninckx - Yanıt
The white latch on the right side for that ribbon won’t close. What should I do?
Gaojhia Vang - Yanıt
Does anyone know if the D5200 and D3300 share the same LCD screen? Ebay, Aliexpress, DHCamera show screens described as D3300/D5200 . I’d rather not pay $200 for a screen replacement I can do myself for <$25
Jeffrey Parker - Yanıt
Does anyone know if the LCD for the D5200 and D3300 are the same? I find screens listed as D5200/D3300
want to replace my D5100 LCD screen as it's already dying and I can't find D5100 LCD screens but found countless D5200 LCD replacement and just want to ask if the d5100 and d5200 share the same LCD?
they're the same 3" 920k screens and look the same too, just want confirmation as I don't want to buy a screen that won't fit mine 😅
Janarthanaan Thamizh Selvan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 27
Son 30 gün: 102
Her zaman: 12,589
