Ana içeriğe geç
Nikon D80 Flash Assembly Replacement
Neye ihtiyacın var
    1. Nikon D80 Flash Assembly Replacement, Flash Assembly: adım 1, 3 resimden 1. Nikon D80 Flash Assembly Replacement, Flash Assembly: adım 1, 3 resimden 2. Nikon D80 Flash Assembly Replacement, Flash Assembly: adım 1, 3 resimden 3.
      • Press the highlighted button to pop the flash up.
      • Otherwise, use a plastic opening tool to gently lever open the flash by inserting the tool into the gap between the flash and the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Nikon D80 Flash Assembly Replacement: adım 2, 1 resimden 1.
      • Use the #00 Phillips-head screwdriver to remove both 4.20 mm screws by rotating the screwdriver to the left.
      FixBot'a Sor
      Yorum Ekle
    3. Nikon D80 Flash Assembly Replacement: adım 3, 2 resimden 1. Nikon D80 Flash Assembly Replacement: adım 3, 2 resimden 2.
      • Using a plastic opening tool, pry open the cover.
      • Be advised, some plastic struts may snap off when you remove the cover.
      FixBot'a Sor
      Yorum Ekle
    4. Nikon D80 Flash Assembly Replacement: adım 4, 2 resimden 1. Nikon D80 Flash Assembly Replacement: adım 4, 2 resimden 2.
      • Using a soldering iron, desolder the orange, tan, and gray wires from the flash assembly.
      • For more information on how to solder and desolder connections, please visit this guide.
      • Use caution while using the hot soldering iron.
      FixBot'a Sor
      Yorum Ekle
    5. Nikon D80 Flash Assembly Replacement: adım 5, 1 resimden 1.
      • Gently remove the flash assembly from the casing.
      • The surface may still be hot, so grab it with caution.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Kevin Horwedel
211 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G1, Leahy Fall 2017 USF Tampa, Team S1-G1, Leahy Fall 2017 üyesi
USFT-LEAHY-F17S1G1
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 15
Son 30 gün: 49
Her zaman: 2,950
